Anchor
scale
scale
Example: Scale
This example shows the effect of the Scale parameter. Note how larger values make the object appear more translucent. The images are rendered without GI to better show the sub-surface scattering. The Single scatter parameter was set to Raytraced (solid).
bordertrue
width30%
width40%
Image slider
startIndex1
Panel
borderStylenone
Scale = 1
Panel
borderStylenone
Scale = 3
Panel
borderStylenone
Scale = 6
width30%
Example: Sub-Surface Color
This example and the next demonstrate the effect of and the relation between the Scatter Color and the Sub-Surface Color parameters. Note how changing the Sub-surface color changes the overall appearance of the material, whereas changing the Scatter Color only modifies the internal scattering component. For all three renders, the Scatter Color is set to green.
bordertrue
width30%
width40%
Image slider
startIndex1
Panel
borderStylenone
Sub Surface Color = Red
Panel
borderStylenone
Sub Surface Color = Green
Panel
borderStylenone
Sub Surface Color = Blue
width30%
Anchor
scatterColor
scatterColor
Example: Scatter Color
The Sub-Surface Color is set to green for all the following renders.
bordertrue
width30%
width40%
Image slider
startIndex1
Panel
borderStylenone
Scatter Color = Red
Panel
borderStylenone
Scatter Color = Green
Panel
borderStylenone
Scatter Color = Blue
width30%
Example: Scatter Radius
This example shows the effect of the Scatter Radius parameter.
bordertrue
width30%
width40%
Image slider
startIndex1
Panel
borderStylenone
Scatter Radius = 1.0cm
Panel
borderStylenone
Scatter Radius = 2.0cm
Panel
borderStylenone
Scatter Radius = 6.0cm
width30%
Anchor
phaseFunction
phaseFunction
Example: Phase Function
This example shows the effect of the Phase Function parameter. This parameter can be likened to the difference between diffuse reflection and glossy reflection on a surface. However, it controls the reflectance and transmittance of a volume. Its effect is quite subtle, and mainly related to the single scattering component of the material.
The red arrow represents a ray of light going through the volume; the black arrows represent possible scattering directions for the ray.
bordertrue
width30%
width40%
Image slider
startIndex1
Panel
borderStylenone
Phase Function = -0.9 (Backward Scattering)
More light comes out.
Phase Function = -0.5 (Backward Scattering)
Panel
borderStylenone
Phase Function = 0 (Isotropic Scattering)
More light exits object.
Panel
borderStylenone
Phase Function = 0.0 (Forward Scattering)
More light is absorbed object.
Phase Function = 0.5 (Forward Scattering)
width30%
Example: Phase Function: Light Source
This example demonstrates the effect of
the Phase
function parameter when there is a light source inside the volume.
 The material uses Color mode: Scatter coefficient and fog color, large Scatter radius and Single scatter: Raytraced (Refractive).
width20%
bordertrue
width
60%
Image slider
minLabel-0.9
maxLabel0.7
Panel
borderStylenone
Image Removed
Image Added
Panel
borderStylenone
Image Removed
Phase Function = 0
Image Added
Panel
borderStylenone
Image Removed
Phase Function = 0.9
Image Added
width
20%
Specular Layer
width60%
Some of the options are available only in Advanced mode.
Reflections – Enables the calculations of reflections. When disabled, only specular highlights are calculated.
Color – Determines the specular color for the material.
Amount – Determines the specular amount for the material. Note that there is an automatic Fresnel falloff applied to the specular component, based on the IOR of the material.
Glossiness – Determines the glossiness (highlights shape). A value of 1.0 produces sharp reflections, lower values produce more blurred reflections and highlights.
Reflection Depth – Specifies the number of reflection bounces for the material.
width5%
width35%
Fancy Bullets
typecircle
  • The BRDFSSS2Complex material computes sub-surface scattering only during the final image rendering. During other GI calculations phases (e.g. light cache or photon mapping), the material is calculated as a diffuse a diffuse one.
  • For the reason explained above, BRDFSSS2Complex will render as a diffuse one with the progressive path tracing mode of the light cache.
  • You can layer several BRDFSSS2Complex materials using a VRayBlendMtl material a Blend material in order to recreate more complex sub-surface scattering effects. In this case, any raytraced single scattering will only be calculated for the base material, but multiple scattering, reflections etc will work correctly for any layer. It might be helpful to use the Prepass ID parameter to make the materials share the same illumination map so that some of the calculations are reused.
  • Materials created with previous version, which are migrated to a default value - Raytraced (geometry_based_sampling = 2)
  • The option Multiple Scatter is now legacy. Materials created with versions prior to V-Ray 5, have their Multiple Scatter migrated to Raytraced.
Here is a list of links and references used when building the BRDFSSS2Complex material.
