Section | |||||||||||||||
Splash Birth
Splash Amount | spbirth – Controls the amount of splash relative to the liquid. This value determines how many splash particles are equal to a single liquid particle in volume. This value also affects the particle size, where larger values decrease the size of splash particles. Note: This parameter is the nearest in functionality to the "birth rate" parameter in previous versions. For more information, see the Splash Amount example below.
Foam on Hit
Dynamics
Section | ||||||||||||||||||||||||||
Anchor | ||||
