width38%
V-Ray Node Space offers a number of nodes arranged in the following categories: Color, Context, Material Generator, Material, Math, Surface and Utility.
V-Ray offers two output (Colored Node) nodes - Material and Two Sided Material. Each Node system holds only one output (Colored) node.
Some of the nodes are texture nodes, used as utility or surface maps.
UI Text Box
typenote
V-Ray Node space is available in Cinema 4D versions 21.1 and later!
UI Text Box
typeinfo
V-Ray Texture Nodes are not interchangeable or compatible with the V-Ray (Classic) Textures.
width5%
width57%
Node Editor with V-Ray nodes in Cinema 4D R25.
width38%
For Cinema 4D version R25 and later
Make sure V-Ray is your Renderer. This is done through Render Settings > Renderer.
Go to the Material Manager and from Create > Materials, select New Node Material.
Alternatively, go to Create > V-Ray > V-Ray Node Materials and select a V-Ray surface material from the list. If the Separate menu for V-Ray materials option in the Preferences is disabled, go to Create > V-Ray > V-Ray Node Materials.
The Node editor opens and you can now work with all available V-Ray nodes.
width5%
width57%
