changes.mady.by.user Kristin Ivanova
Saved on Jun 24, 2021
changes.mady.by.user Kristina Gaytandzhieva
Saved on Feb 24, 2023
Texture – An input slot to connect the texture to.
Mix Strength – A multiplier for the connected texture - blends between the value and the texture.
Texture Clamp – When enabled, the output is clamped to 1 from above (always clamped to 0 from below).
Result Multiplier – Specifies a multiplier for the end result.
Image RemovedImage Added
