This page provides information about the Combine Float node in V-Ray for Cinema 4D.
Texture – An input slot to connect the texture to.
Mix Strength – A multiplier for the connected texture - blends between the value and the texture.
Texture Clamp – When enabled, the output is clamped to 1 from above (always clamped to 0 from below).
Result Multiplier – Specifies a multiplier for the end result.
