The Color Arithmetic node performs an arithmetic operation between two colors/textures.
For the example here, Color Ais set to red and Color Bis set to blue. The Modeis set to absolute difference Absolute Differenceand both multiplicators are at 0.5.
width
5%
width
38%
Image RemovedImage Added
width
57%
Color A – Specifies the first color/texture.
Mult A – A multiplier for Color A.
Color B – Specifies the second color/texture.
Mult B – A multiplier for Color B.
Result AAlpha–
Mode – Specifies the calculation method for the two colors/textures:
Result A Result B Product Sum Difference Power Division Minimum Maximum Absolute Differenceresult_a result_b product sum difference power division minimum maximum absolute difference
