Section | |||||||||||||||
Properties
Example: Curvature and Color to UVW Node
In this example, the Color to UVW Node helps mapping a Curvature node with a colored Ramp.
In this example, a Ramp node is used along with Color to UVW node to map a Falloff texture node across the V direction of the image.
This example shows a Ramp node that colors a Bitmap image using the Color to UVW node.
