This page provides information about the V-Ray Renderable Spline tag in Cinema 4D.
The Renderable Spline tag allows V-Ray to render splines. Splines can also be assigned with texture maps.
UI Text Box
typeinfo
Starting with Cinema 4D 2023.1, the Renderable Spline tag resides in Extensions > V-Ray tags
width50%
Render – Enables V-Ray to render of the spline.
Width Multiplier – Specifies the width of the spline in centimeters.
Width Mode – Specifies how the width of the spline is defined:
Linear – Introduces a linear (constant) value along the whole spline.
Spline – Introduces a width based on a curve, allowing different widths between different points of the spline.
UI Text Box
typetip
You can create a new curve point using Ctrl + Left-click or by using a curve preset.
Start Width/ End Width – Splines in Cinema 4D do not have thickness, and these . These parameters must be used to specify the start/end width of the spline.
Lock End Width – When enabled, Start Width controls the constant thickness along the spline.
width5%
width45%
Width Mode Linear
Width Mode Spline with preset loaded
