width60%
V-Ray Rectangle Light component creates a rectangle light source. This light source can be connected to the V-Ray Render which will automatically add it to the rendered scene. If a list of input Planes is connected to this component, multiple lights are generated. Multiple Size values can also be used.
The Number of Instances tag at thebottom of the component indicates how many times the object is currently being instanced.
The number of input Planes determines the lights count. The number of Size values do not affect the lights count.
width5%
width35%
Image Modified
Input Parameters
On (Boolean) – Enables or disables the light source.
Plane Base plane (Base plane) – The rectangle light base plane, where its geometry is positioned and orientated along.
Intensity (Number) – Provides an option to control the light source intensity. Calculated in Default (Scalar) units. Calculated in the specified units.
Intensity Units (Integer) – Specifies the light unit of measurement. Using correct units is essential when working with physical camera exposure. The light automatically takes the scene units scale into consideration to produce correct result for the scale being worked in.
Default (Scalar) – The color and multiplier directly determine the visible color of the light without any conversion. The light surface appears with the given color in the final image when seen directly by the camera.
Luminous Power (Lumens) – Total emitted visible light power measured in lumens. The intensity of the light does not depend on its size. A typical 100W incandescent light bulb emits about 1500 lumens of light.
Luminance (lm/m^2/sr) – Visible light surface power measured in lumens per square meter per steradian. The intensity of the light depends on its size.
Radiant Power (W) – Total emitted visible light power measured in watts. The intensity of the light does not depend on its size. This is not the same as the electric power consumed by a light bulb. A typical 100W light bulb only emits between 2 and 3 watts as visible light.
Radiance (W/m^2/sr) – Visible light surface power measured in watts per square meter per steradian. The intensity of the light depends on its size.
Invisible (Boolean) – This option makes the light source invisible. It does not affect the light source's illuminance.
U/V Size (Number) – Controls the U/V size of the light measured in scene units.
DirDirectionality (Number) – Specifies the spread of the light beam. Value of 0 emits light equally in all directions. Increasing the value makes the light beam more narrow and concentrates it in one direction.
Output Parameters
Add Light (Generic Data)– Light output that can be connected to a V-Ray Render component.
Example
Image Removed
width50%
Image Removed
width50%
Image Removed
Rectangle Light component connection connection. Note the toggled off Simple Light Rig plugged used as an override. If there is no Light Rig input in the V-Ray Render component it will always internally create one.
width10%
width80%
Image Added
width10%
width10%
width80%
Image Added
width10%
