UI Text Box
typenote
For Enscape assets to render properly in V-Ray, you have to initialize Enscape first. This needs to be done only once for the assets data to be populated in the project. Afterwards, this step must be repeated only after introducing more new assets. Once done, you don't have to start Enscape again, even if you save the project and reopen it later.
Settings and camera exposure from Enscape are not transferred to V-Ray. V-Ray settings might have to be adjusted additionally.
Enscape procedural clouds can be replicated in V-Ray using V-Ray Procedural clouds and can also be animated for sun studies.
To stop the Enscape - V-Ray workflow, go to V-Ray menu > Preferences and disable the Enscape Compatibility option.
UI Text Box
typetip
Starting with V-Ray6Ray 6, Update 1, some of Enscape’s visual settings can now be transferred to V-Ray. This helps with matching Enscape’s environment and illumination - Sunlight, Sky, and Camera exposure. The synchronization is done by manually performing the Apply Enscape Settings action from the V-Ray / Tools menu.
