width50%60%
The Atmosphere Render Element stores only atmospheric or volumetric participating media such as Environment Fog or Aerial Perspective. This render element can then be used to enhance or color-correct just the atmospheric component of the image during the compositing process.
When atmospheric effects or fog is included in a scene, they will render into the Beauty (RGB color) channel, and should also be output as the atmosphere channel for compositing use.
UI Path: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel >  V-Ray Color Channel (RE) > Type > Atmosphere
width5%
45%
width35%
Image AddedImage Removed
Attributes
width50%60%
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – When enabled, the Color Mapping options in the render settings are applied to the current render channel.
Consider For AA – When enabled, anti-aliasing is used where possible.
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler tab of the Sampler tab of the V-Ray Renderer node.
Denoise – Enables the render element's denoising, provided the V-Ray Denoiser render element is present.
VFB Color Corrections – Applies the post render color adjustments made from the VFB.
width5%
width45%35%
Image RemovedImage Added
Common Uses
The Atmospheric Effects Atmosphere Render Element is useful for changing the appearance of the atmosphere and volumetric effects in a rendered image using compositing or image editing software. Below is an example of its use.
width5%
width45%
Image Removed
Atmosphere Render Element, with fog
generated by EnvironmentFog
width45%
Image Removed
Original Beauty composite
width5%
width5%
width90%
Image Removed
Color of atmosphere changed and intensity increased
width5%
Compositing Formula
Atmosphere + Beauty = Final Image
In the example, fog is generated using the V-Ray EnvironmentFog. The fog is assigned a warmer color and the intensity is increased, using the Atmosphere RE.
Before after
darktrue
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Compositing Formula
The V-Ray Atmosphere Render Element is added to the Beauty render to form the final image.
