This page provides information on the Raw Direct Light Render Element.
Section | |||||||||||||||
Attributes
UI Text Box | ||
This render element is not supported with V-Ray GPU rendering. |
Common uses
The Raw Direct Light Render Element is useful for changing the appearance of direct light after rendering in a compositing or image editing software. Below are a couple of examples of its use. In this set of render elements, direct light affects the back of the alien figure the most due to a strong back-light in the scene as well as the top of the circular machine above the figureexample, you can see how the image looks before and after post-production.
Sectionbefore-after | ||||||||||||||||||
| width
Underlying Compositing Equation
Raw Direct Light x Diffuse = Direct Light
