width50%
2D cel and cartoon effects can easily be achieved with the V-Ray Toon Material. Use this material to make your scene get that hand-drawn look. Controlling the shadows and lights received by the material in combination with material transparency, gotten from Object or Material IDs, allows for fine-tuning the result. You can take advantage from the other standard V-Ray material options such as reflection, refraction, anisotropy, subsurface scattering and bump/normal mapping to set up the render to your liking.
Combine with the Toon atmospheric effect to add custom outlines for inky effect.
UI Path: ||mat Network|| > V-Ray > Material V-Ray Toon Material
Image Removed
width5%
width45%
