width50%
Clear VFB in between renders – When enabled, the frame buffer is reset to black before each rendering. When disabled, the last render stays on and is gradually replaced by the new one.
Render stamp – When enabled, text with render information overlays on the bottom right corner of the rendered output. You can click the little > button before the checkbox to see the list of all available %-variables you can use.
UI Text Box
typetip
The content of the render stamp accepts text and the special %-variables listed under the > button.
Expand
titleClick here to see the available variables for the render stamp
Renderstamp varialbleExplanation
code
%ptp
Performance:
Preprocessing
Parsing time
(in
milliseconds)
%ptg
Performance:
Geometry
preprocessing
time
(in
milliseconds)
%pts
Performance:
Secondary
solver
precomputation
time
(in
milliseconds)
%ptd
Performance:
Denoising
time
(in
milliseconds)
%pt
Performance:
Total
elapsed
time
%pr
Performance:
Rays
per
second
%ps
Performance:
Rays
per
sample
%pp
Performance:
Passes
%pe
Performance:
Noise
level
%sl
Scene:
Number
of
light
primitives
%so
Scene:
Number
of
objects %su -
objects
%siScene:
Number
of
unique primitives %sd -
instanced primitives
%suScene:
Number
of
displacement primitives %si -
unique primitives
%sdScene:
Number
of
instanced
%c
CPU
name
%ct
Number
of
CPU
thread(s)
%bn
Corona
build
name
%b
Corona
build
date %d - Current
datestamp
%dCurrent date/time
%h
Current
time
%f
Currently
rendered
filename
%n
Actual
frame
number
%o
Output
filename
%v
Current
camera
name
%i
This
computer
name
%mc
Memory
currently
used
by
Corona
%mcp
Peak
memory
used
by
Corona
%mp
Virtual
memory
currently
used
by Cinema 4D + Corona %mpp - Peak virtual memory used by Cinema 4D + Corona %ms - Virtual memory currently used by the system %bpn - Corona plugin build name
by the host application + Corona Renderer
%mppPeak virtual memory used by the host application + Corona Renderer for that session of the host application
%msVirtual memory used by the system
width5%
width45%
Image filter
width50%
Type – The image pre-filters suppress Moiré patterns and other artifacts by slightly blurring the image. Most filters produce visually almost equal results.
Available filter types are:
High Quality – This filter produces better anti-aliasing and DoF than other filters. It does not work with AI denoising.
Box – This filter has the most significant blurring of all the filters.
Tent – This filter offers a good tradeoff between blurring and sharpness.
Symmetric tent – This filter is a variant of the tent filter with bigger diagonal blurring.
Parabolic – This filter has the second most significant blurring of the filters.
Hann – This filter has low diagonal blurring and a smaller tail than the other filters.
Blackman-Harris – This filter is the sharpest, resulting in the least blurring of all the filters (except for None).
None – This option disables the filtering entirely, resulting in a perfectly sharp image.
Width [px] – The filter radius in pixels. A larger value slightly blurs the image to improve anti-aliasing and removes the Moiré effect. The default value of 2.0 works fine in most cases.
Highlight clamping – Clamps all samples to this maximum value before they are written into the frame buffer. This can help to reduce noise and improve anti-aliasing around bright light edges at the cost of bias. Setting the value too low results in visibly clamped highlights. Set to 0 to disable for unbiased, highest-quality output.
width5%
width45%
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
aligncenter
classcoronatabsc4d
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkGeneral settingsSettings
General settings
Textboxcard
CardPageLinkCamera-Postprocessing
Camera/Postprocessing
Textboxcard
PageToIncludeInstallation
CardPageLinkScene Environment
Scene environment
Textboxcard
CardPageLinkPerformance Settings
Performance settings
Textboxcard
CardPageLinkSecondary GI - UHD Cache
Secondary GI: UHD Cache
Textboxcard
PageToIncludeGetting Started
CardPageLinkTeam Render
Team render
