Section | |||||||||||||||
Particle Preview
UI Text Box | ||
The parameters here control the visualization of Particle Types generated by the Simulator. Phoenix can only preview the Particle Types present in the cache file for the current frame. |
UI Text Box | ||
You can specify a Particle Channel to use as a basis for adjusting the particle preview color, using the Scale Color By option. For example, you could set the Scale Color By option to the Speed particle channel, so that the faster the particles move, the whiter they appear in the preview. You can find more info on Particle Channels from the Particle Channel Ranges page. |
Voxel Preview
Bake Streamlines
Slice Preview
UI Text Box | ||
UI Text Box | ||
Slice |
UI Text Box | ||
The Slice preview displays only a single slice of voxels which can be convenient for debugging and fine-tuning a simulation. |
