This article explains the settings and values for the Corona AO shader.
width50%
The Corona Ambient Occlusion (Corona AO) is a shader that can be used to color the concave and convex areas of a surface. By default, when used as diffuse color, it will darken crevices and cavities of objects while also brightening flat and raised areas. The Corona AO shader can also be used to create advanced materials, such as rusted metal, worn wood, and scratched paint, or to provide artistic control over the overall scene appearance.
width5%
width45%
Shader properties
width50%
Occluded color – This is the color that is used for occluded areas of the geometry.
Level – This is the intensity (also considered as the visibility) of the occlusion.
Occluded texture – Using this option, the occlusion can be controlled by a texture map or shader.
Texture – Defines the texture map or shader that will be used for AO.
Mix mode – Controls the blending mode of the texture map or shader.
Mix strength – Controls the intensity of the texture map or shader that is being used.
width5%
width45%
width1%
width32%
Image slider
Corona AO Occluded color
Panel
titleOccluded color = Black
Panel
titleOccluded color = Red
Panel
titleOccluded color = Green
width1%
width32%
Image slider
Corona AO Occluded color - Level
Panel
titleLevel - 0%
Panel
titleLevel - 50%
Panel
titleLevel - 100%
width1%
width32%
Image slider
Corona AO Occluded Texture
Panel
titleNo texture/shader
Panel
titleTexture map
Panel
titleTexture map
width1%
width32%
Image slider
Corona AO Unoccluded color
Panel
titleUnoccluded color = White
Panel
titleUnoccluded color = Orange
Panel
titleUnoccluded color = Green
width1%
width32%
Image slider
Corona AO Unoccluded color - Level
Panel
titleLevel - 0%
Panel
titleLevel - 50%
Panel
titleLevel - 100%
width1%
width32%
Image slider
Corona AO Unoccluded Texture
Panel
Panel
titleTexture map
Panel
titleTexture map
width1%
width32%
Image slider
Corona AO Max distance
Panel
titleMax distance = 5cm
Panel
titleMax distance = 20cm
Panel
titleMax distance = 40cm
width1%
width32%
Image slider
Corona AO Max distance texture
Panel
titleMax distance texture = None
Panel
titleMax distance texture = Texture map
Panel
width1%
width32%
Image slider
Corona AO Max distance texture (Mix strength)
Panel
titleMix strength = 100%
Panel
titleMix strength = 50%
Panel
titleMix strength = 0%
width1%
width32%
Image slider
Corona AO Color Spread
Panel
titleColor spread = 0%
Panel
titleColor spread = 50%
Panel
titleColor spread = 100%
width1%
width32%
Image slider
Corona AO Ray directionality
Panel
titleRay directionality = 0%
Panel
titleRay directionality = 35%
Panel
titleRay directionality = 70%
width1%
width32%
Image slider
Corona AO Max samples
Panel
titleMax samples = 5
Panel
titleMax samples = 20
Panel
titleMax samples = 50
