Section | |||||||||||||||||||||
UI Paths
||V-Ray Asset Editor|| > Materials (right-click) > Outline Override
UI Options
Section | ||||||||||||||||||||||
Attributes
The attributes from the following expandable menus are available for the Outline Outline Override material.
Anchor | ||||
Expand | |||||||||||||||||
Translucency
Bump
Expand | |||||||||||||||||||||||||||
Displacement
Raytrace Properties
Override
Material ID
Anchor | ||||
Example: Line Width
This example shows the effect of the Width parameter. The Inner Line Control is disabled.
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Inner Line Control
This example shows the effect of the Inner Line Control parameter. The main lines are black and the Inner Lines are red. The Width of the main lines is set to 2, while that of the Inner Lines is set to 3.
Anchor | ||||
Example: Line Color
This examples shows the effect of the Line Color and Inner Line Color parameters.
