width60%
Stores information about cast shadows calculated from the lighting in the scene. It is a reverse image in the sense that white areas indicate shadows while black areas indicate the surface is directly illuminated by a light source.
width5%
width35%
Before after
afterLabelBeauty
beforeLabelRaw Shadows
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image Removed
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Raw Shadows
||V-Ray Asset Editor|| > Create Asset (left-click) > Render ElementsRaw Shadows
width60%
Denoise – Specifies whether to denoise this render element.
width5%
width35%
Common Uses
width60%
The Raw Shadows Render Element is useful for changing the appearance of shadowed areas, after rending, inside a compositing or image editing application. In the example, the Raw Shadows are added (plus) to the Raw Light Render Element. See how the render looks before and after compositing.
width5%
width35%
Before after
darktrue
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Compositing
width10%
width80%
Raw Shadows x Diffuse = Shadows
Image Added
width10%
