width60%
Shows surface normals in the scene. Stores the camera space normal map using the geometry's surface normals. Material bump and normal maps don't affect this element.
width5%
width35%
Before after
afterLabelBeauty
beforeLabelGeometry Normals
Panel
borderStylenone
Image Added
Panel
borderStylenone
Image Added
Image Removed
UI Paths
||V-Ray Asset Editor|| > Render Elements (right-click) > Geometry Normals
||V-Ray Asset Editor|| > Create Asset (left-click) > Render Elements Geometry Normals
Geometry Normals Color Generation
width60%
The Geometry Normals Render Element uses screen space to determine the colors in the render element.  With screen space in the camera view:
The X axis runs left-right perpendicular to the camera viewing angle. This is represented in the Red channel of Geometry Normals with 1 being left-facing geometry and 0 being right-facing geometry.
The Y runs up-down perpendicular to the viewing angle.  This is represented in the Green channel of Geometry Normals with 1 being up-facing geometry and 0 being down-facing geometry.
The Z runs forward-back to the viewing angle.  This is represented in the Blue channel of Geometry Normals with 1 being forward-facing geometry and 0 being back-facing geometry.
width5%
width35%
Image Added
