Add Light (Generic Data)– Light output that can be connected to a V-Ray Render component.
Example
Light Rectangle Light component connectionconnection. Note the toggled off Simple Light Rig plugged that an Environment component with a black color plugged in the GI input parameter is used as an override to turn off the default Environment lighting. If there is no Light Rig Environment input in the Render component V-Ray Render component it will always creates one internally create one.
Section | |||||||||||||||||||
Section | ||||||||||||||||||||||
