The Simulation Speed rollout helps you identify the heaviest computation phases of the simulation and provides tips on how to get results faster and more efficiently.
width40%
UI Text Box
typetip
UI Path: ||Select PhoenixFDSim|| > Attribute Editor > Simulation Speed rollout
UI Text Box
typeinfo
The Simulation Speed rollout shows a breakdown of the phases of your simulation, highlighting those that are taking the longest to complete. For each phase identified, advice is given on how to optimize it.
width5%
width55%60%
