Floatingpagetoc
This page provides information about the supported .vrscene features exported from V-Ray for SketchUp/Rhino.
UI Text Box | ||
Chaos Vantage has better support for .vrscene files exported from V-Ray Next and later. It is recommend to use the latest officially released V-Ray version. |
Lights
UI | Native Name | V-Ray Plugin Name | Support | |
Standard Rhino Lights
| Light Type: Point Spot Directional Linear Rectangular |
LightOmni LightSpot MayaLightDirect LightRectangle LightRectangle |
Enabled | enabled | |||
Color | color | |||
Intensity | intensity | |||
Units: Default (Scalar) Lumens Luminance Radiant power (W) Radiance |
units=0 units=1 units=2 units=3 units=4 |
V-Ray Lights
| V-Ray Rectangle Light | LightRectangle | ||
| Enable | enabled | ||
Color/Texture | color | |||
Units: Default (Scalar) Luminous Power (Lumens) Liminance (lm/m^2/sr) Radiant power (W) Radiance (W/m^2/sr) |
Shape: Rectangle Disc |
is_disk=0 is_disk=1 |
U Size/Size | u_size | |||
V Size | v_size | |||
Directionality | directional | |||
Portal Light: Accurate Simple |
lightPortal=1 lightPortal=2 |
Invisible | invisible | |||
No Decay | noDecay | |||
Shadows | shadows | |||
Double Sided | doubleSided | |||
Affect Diffuse | affectDiffuse | |||
Diffuse contribution | diffuse_contribution | |||
Affect Specular | affectSpecular | |||
Specular contribution | specular_contribution | |||
Affect Reflections | affectReflections | |||
Tex. Resolution | tex_resolution | |||
Caustic Subdivs | causticSubdivs | |||
V-Ray Sphere Light | LightSphere | |||
Color | color | |||
Units: Default (Scalar) Luminous Power (Lumens) Liminance (lm/m^2/sr) Radiant power (W) Radiance (W/m^2/sr) | units=0 units=1 units=2 units=3 units=4 |
Size | u_size | |||
V-Ray Spot Light | LightSpot | |||
Cone Angle | coneAngle | |||
Penumbra Angle | penumbraAngle | |||
Penumbra Falloff: Linear Smooth Cubic |
falloffType=0 falloffType=1 |
Decay: No Decay Inverse Inverse Square Inverse Cube |
decay=0 decay=1 decay=2 decay=3 |
Shadow Radius | shadowRadius | |||
Caustics Subdivs | causticSubdivs | |||
V-Ray IES Light | LightIES | |||
Color | color | |||
Intensity (lm) | power | |||
IES Light File | ies_file | |||
Shape: From IES File Point Circle Sphere |
ies_light_shape=-1 ies_light_shape=0 ies_light_shape=1 ies_light_shape=2 |
Diameter | ies_light_diameter | |||
V-Ray Omni Light | LightOmni | |||
Color | color | |||
decay_type=0 decay_type=1 decay_type=2 decay_type=3 |
V-Ray Dome Light | LightDome | |||
Color/Texture HDR | color | |||
Shape: Hemisphere Sphere |
dome_spherical=0 dome_spherical=1 |
Use Transform | – | |||
Adaptive | dome_adaptive | |||
Affect Alpha | affect_alpha | |||
Target Radius | dome_targetRadius | |||
Emit Distance | dome_emitRadius | |||
V-Ray Mesh Light | LightMesh | |||
V-Ray Sun Light | SunLight | |||
Color | color | |||
Color Mode: Filter Direct Override |
color_mode=0 color_mode=1 color_mode=2 |
Intensity Multiplier | intensity_multiplier | |||
Size Multiplier | size_multiplier | |||
Sky Model: Preetham et al CIE Clear CIE Overcast Hosek et al |
sky_model.0 sky_model=1 sky_model=2 sky_model=3 |
Horizontal Illumination | horiz_illum | |||
Turbidity | turbidity | |||
Ozone | ozone | |||
Albedo Color | ground_albedo | |||
Bend Angle | blend_angle | |||
Horizon Offset | horizon_offset | |||
Caustic Subdivisions | causticSubdivs | |||
Emit Radius | – |
Camera
UI | Native name | V-Ray plugin name (plugin/parameter) | Support |
Camera | CameraPhysical | ||
Type: Standard VR Spherical Panorama VR Cubemap |
SettingsCamera/type=0 SettingsCamera/type=9 SettingsCamera/type=10 |
Stereo | RenderView/stereo_on | ||
Enable Exposure | exposure | ||
Exposure Value (EV) | combination of ISO, f_number, shutter_speed | ||
Exposure Value (EV) Auto | SettingsCamera/auto_exposure | ||
Compensation | SettingsCamera/auto_exposure_compensation | ||
White Balance | white_balance | ||
White Balance Auto | SettingsCamera/auto_white_balance | ||
Auto Values | – | ||
Depth of Field | use_dof | ||
Defocus | combination of ISO, f_number | ||
Focus Source: Fixed Distance Camera Target Fixed Point |
Focus Distance | focus_distance | ||
Vignetting | vignetting | ||
Vertical Tilt | lens_shift | ||
Film Sensitivity (ISO) | ISO | ||
Aperture (F Number) | f_number | ||
Shutter Speed | shutter_speed | ||
Blades | blades_num | ||
Enable Blades | blades_enable | ||
Center Bias | center_bias | ||
Rotation | blades_rotation | ||
Anisotropy | anisotropy |
Geometry
V-Ray Clipper | VRayClipper | |
V-Ray Displacement | GeomDisplacedMesh | |
V-Ray Fur | GeomHair | |
V-Ray Plane | GeomPlane | |
V-Ray Proxy | GeomMeshFile | |
V-Ray Scene | VRayScene |
Materials
Tabs Page | |||||||||||||||||||||||||||
VRayMtl
Tabs Page | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Maps
Footnotes
1
Anchor | ||||
