This page provides information about the supported .vrscene features exported from V-Ray for SketchUp/Rhino.
Lights
UI | Native Name | V-Ray Plugin Name | Support | |
Standard Rhino Lights
| Light Type: Point Spot Directional Linear Rectangular |
LightOmni LightSpot MayaLightDirect LightRectangle LightRectangle |
Enabled | enabled | |||
Color | color | |||
Intensity | intensity | |||
Units: Default (Scalar) Lumens Luminance Radiant power (W) Radiance |
units=0 units=1 units=2 units=3 units=4 |
V-Ray Lights
| V-Ray Rectangle Light | LightRectangle | ||
| Enable | enabled | ![]() | |
Color/Texture | color | |||
Units: Default (Scalar) Luminous Power (Lumens) Liminance (lm/m^2/sr) Radiant power (W) Radiance (W/m^2/sr) |
Shape: Rectangle Disc |
is_disk=0 is_disk=1 |
U Size/Size | u_size | |||
V Size | v_size | |||
Directionality | directional | |||
Portal Light: Accurate Simple |
lightPortal=1 lightPortal=2 |
Invisible | invisible | |||
No Decay | noDecay | |||
Shadows | shadows | |||
Double Sided | doubleSided | |||
Affect Diffuse | affectDiffuse | |||
Diffuse contribution | diffuse_contribution | |||
Affect Specular | affectSpecular | |||
Specular contribution | specular_contribution | |||
Affect Reflections | affectReflections | |||
Tex. Resolution | tex_resolution | |||
Caustic Subdivs | causticSubdivs | |||
V-Ray Sphere Light | LightSphere | |||
Color | color | |||
Units: Default (Scalar) Luminous Power (Lumens) Liminance (lm/m^2/sr) Radiant power (W) Radiance (W/m^2/sr) | units=0 units=1 units=2 units=3 units=4 |
Size | u_size | |||
V-Ray Spot Light | LightSpot | |||
Cone Angle | coneAngle | |||
Penumbra Angle | penumbraAngle | |||
Penumbra Falloff: Linear Smooth Cubic |
falloffType=0 falloffType=1 |
Decay: No Decay Inverse Inverse Square Inverse Cube |
decay=0 decay=1 decay=2 decay=3 |
Shadow Radius | shadowRadius | |||
Caustics Subdivs | causticSubdivs | |||
V-Ray IES Light | LightIES | |||
Color | color | |||
Intensity (lm) | power | |||
IES Light File | ies_file | |||
Shape: From IES File Point Circle Sphere |
ies_light_shape=-1 ies_light_shape=0 ies_light_shape=1 ies_light_shape=2 |
Diameter | ies_light_diameter | |||
V-Ray Omni Light | LightOmni | |||
Color | color | |||
decay_type=0 decay_type=1 decay_type=2 decay_type=3 |
V-Ray Dome Light | LightDome | |||
Color/Texture HDR | color | |||
Shape: Hemisphere Sphere |
dome_spherical=0 dome_spherical=1 |
Use Transform | – | ![]() | ||
Adaptive | dome_adaptive | |||
Affect Alpha | affect_alpha | |||
Target Radius | dome_targetRadius | ![]() | ||
Emit Distance | dome_emitRadius | ![]() | ||
V-Ray Mesh Light | LightMesh | |||
V-Ray Sun Light | SunLight | |||
Color | color | ![]() | ||
Color Mode: Filter Direct Override |
color_mode=0 color_mode=1 color_mode=2 |
Intensity Multiplier | intensity_multiplier | ![]() | ||
Size Multiplier | size_multiplier | ![]() | ||
Sky Model: Preetham et al CIE Clear CIE Overcast Hosek et al |
sky_model.0 sky_model=1 sky_model=2 sky_model=3 |
Horizontal Illumination | horiz_illum | ![]() | ||
Turbidity | turbidity | ![]() | ||
Ozone | ozone | ![]() | ||
Albedo Color | ground_albedo | ![]() | ||
Bend Angle | blend_angle | ![]() | ||
Horizon Offset | horizon_offset | ![]() | ||
Invisible | invisible | ![]() | ||
Shadows | shadows | ![]() | ||
Affect Diffuse | affectDiffuse | ![]() | ||
Affect Specular | affectSpecular | ![]() | ||
Caustic Subdivisions | causticSubdivs | ![]() | ||
Emit Radius | – | ![]() |
Camera
UI | Native name | V-Ray plugin name (plugin/parameter) | Support |
Camera | CameraPhysical | ||
Type: Standard VR Spherical Panorama VR Cubemap |
SettingsCamera/type=0 SettingsCamera/type=9 SettingsCamera/type=10 |
Stereo | RenderView/stereo_on | ![]() | |
Enable Exposure | exposure | ![]() | |
Exposure Value (EV) | combination of ISO, f_number, shutter_speed | ![]() | |
Exposure Value (EV) Auto | SettingsCamera/auto_exposure | ![]() | |
Compensation | SettingsCamera/auto_exposure_compensation | ![]() | |
White Balance | white_balance | ![]() | |
White Balance Auto | SettingsCamera/auto_white_balance | ![]() | |
Auto Values | – | ![]() | |
Depth of Field | use_dof | ![]() | |
Defocus | combination of ISO, f_number | ![]() | |
Focus Source: Fixed Distance Camera Target Fixed Point |
Focus Distance | focus_distance | ![]() | |
Vignetting | vignetting | ![]() | |
Vertical Tilt | lens_shift | ![]() | |
Film Sensitivity (ISO) | ISO | ![]() | |
Aperture (F Number) | f_number | ![]() | |
Shutter Speed | shutter_speed | ![]() | |
Blades | blades_num | ![]() | |
Enable Blades | blades_enable | ![]() | |
Center Bias | center_bias | ![]() | |
Rotation | blades_rotation | ![]() | |
Anisotropy | anisotropy | ![]() |
Geometry
V-Ray Clipper | VRayClipper | |
V-Ray Displacement | GeomDisplacedMesh | |
V-Ray Fur | GeomHair | |
V-Ray Plane | GeomPlane | |
V-Ray Proxy | GeomMeshFile | |
V-Ray Scene | VRayScene |
Materials
Bump | BRDFBump |
Blend | BRDFLayered |
Car Paint | BRDFCarPaint |
Emissive | BRDFLight |
Subsurface Scattering | BRDFSSS2Complex |
Stochastic Flakes | BRDFStochasticFlakes |
Two Sided | Mtl2Sided |
Toon Material | BRDFToonMtl | Loads as BRDFVRayMtl, toon parameters are ignored. |
VRayMtl
UI | Native name | V-Ray plugin Name (plugin/parameter) | Support |
Generic | BRDFVRayMtl | ||
Diffuse | diffuse | ![]() | |
Diffuse Texture | diffuse | ![]() | |
Roughness | roughness | ![]() | |
Roughness Texture | roughness | ![]() | |
Reflection Color | reflect | ![]() | |
Reflection Color Texture | reflect | ![]() | |
Reflection Glossiness | reflect_glossiness | ![]() | |
Reflection Glossiness Texture | reflect_glossiness | ![]() | |
Fresnel | fresnel | ![]() | |
Reflection IOR | fresnel_ior | ![]() | |
Reflection IOR Texture | fresnel_ior | ![]() | |
Metalness | metalness | ![]() | |
Metalness Texture | metalness | ![]() | |
GGX Tail Falloff | gtr_gamma | ![]() | |
Surface Control: Use Glossiness Use Roughness |
option_use_roughness=0 option_use_roughness=1 |
BRDF Type: Phong Blinn Ward Microfacet GTR (GGX) |
brdf_type=0 brdf_type=1 brdf_type=2 brdf_type=4 |
Back Side Reflect | option_reflect_on_back | ||
Max Depth | reflect_depth | ![]() | |
Affect Channels: Color only Color+alpha All Channels |
refract_affect_alpha=0 refract_affect_alpha=1 refract_affect_alpha=2 |
Trace Reflections | reflect_trace | ||
Anisotropy | anisotropy | ![]() | |
Anisotropy Texture | anisotropy | ![]() | |
Rotation | anisotropy_rotation | ![]() | |
Rotation Texture | anisotropy_rotation | ![]() | |
Derivation: Local axis Map channel |
anisotropy_derivation=0 anisotropy_derivation=0 |
Local Axis: X Y Z |
anisotropy_axis=0 anisotropy_axis=1 anisotropy_axis=2 |
Map Channel/Set | anisotropy_derivation | ![]() | |
Distance on | reflect_dim_distance | ![]() | |
Distance | reflect_dim_distance_on | ![]() | |
Dim Falloff | reflect_dim_distance_falloff | ![]() | |
Translucency set to None Translucency set to Volumetric Translucency set to SSS | Refraction Color | refract | ![]() |
Refraction Color Texture | refract | ![]() | |
IOR | refract_ior | ![]() | |
IOR Texture | refract_ior | ![]() | |
Refraction Glossiness | refract_glossiness | ![]() | |
Refraction Glossiness Texture | refract_glossiness | ![]() | |
Thin-Walled | refract_thin_walled | ![]() | |
Fog Color | fog_color | ||
Fog Color Texture | fog_color_tex | ![]() | |
Depth (cm) / Scale (cm) | fog_mult | ||
Translucency: None Volumetric SSS |
translucency=0 translucency=4 translucency=6 |
Scatter Color / SSS Color | translucency_color | ||
Scatter Color Texture / SSS Color Texture | translucency_color | ||
SSS Amount | translucency_amount | ||
SSS Amount Texture | translucency_amount | ||
Affect Shadows | refract_affect_shadows | ![]() | |
Fog Units Scaling | fog_unit_scale_on | ![]() | |
Max depth | refract_depth | ![]() | |
Trace Refractions | refract_trace | ||
Dispersion on | dispersion_on | ![]() | |
Abbe | dispersion | ![]() | |
| Fog Scattering on | translucency | ![]() |
Type: Hard (wax) Hybrid |
translucency=1 translucency=3 |
Back-side Color | translucency_color | ![]() | |
Scatter Coeff | translucency_scatter_coeff | ![]() | |
Fwd/back Coeff | translucency_scatter_dir | ![]() | |
Thickness | translucency_thickness | ![]() | |
Light Multiplier | translucency_light_mult | ![]() | |
Coat Amount | coat_amount | ||
Coat Amount Texture | coat_amount | ||
Coat Color | coat_color | ||
Coat Color Texture | coat_color | ||
Coat Glossiness | coat_glossiness | ||
Coat Glossiness Texture | coat_glossiness | ||
Coat IOR | coat_ior | ||
Coat IOR Texture | coat_ior | ||
| Coat Bump Enabled | coat_bump_lock | ![]() |
Coat Bump Mode: Bump Map Bump Texture Channel Normal Map |
coat_bump_type=0 coat_bump_type=5 coat_bump_type=1 | | |
Coat Bump Map Texture | coat_bump_map | ![]() | |
Coat Bump Amount | coat_bump_amount | ||
Coat Bump Amount Texture | coat_bump_amount | ||
Sheen Color | sheen_color | ||
Sheen Color Texture | sheen_color | ||
Sheen Glossiness | sheen_glossiness | ||
Sheen Glossiness Texture | sheen_glossiness | ||
| Opacity | opacity | ![]() |
Opacity Texture | opacity | ![]() | |
Custom Source: DIffuse Texture Alpha Opacity Texture Alpha |
opacity/TexCombineFloat opacity/TexAColorChannel/mode=3 |
Mode: Normal Clip Stochastic |
opacity_mode=0 opacity_mode=1 opacity_mode=2 |
Bump Mode: Bump Map Normal Map |
bump_type=0 bump_type=1 |
Bump Map Texture | bump_map | ![]() | |
Bump Amount | bump_amount | ![]() | |
Bump Amount Texture | bump_amount | ![]() | |
Mode: Multiply Blend amount | TexCombineColor/color TexCombineColor/texture_multiplier |
Color | diffuse/TexCombineColor/texture_multiplier | ![]() | |
Reflection Color | reflect/TexCombineColor/texture_multiplier | ![]() | |
Reflection Glossiness | reflect_glossiness/TexCombineColor/texture_multiplier | ![]() | |
Refraction Color | refract/TexCombineColor/texture_multiplier | ![]() | |
IOR | refract_ior/TexCombineColor/texture_multiplier | ![]() | |
Refraction Glossiness | refract_glossiness/TexCombineColor/texture_multiplier | ![]() | |
Opacity | opacity/TexCombineColor/texture_multiplier | ![]() | |
Emissive | BRDFLight | ||
Color Texture | color | ![]() | |
Intensity | colorMultiplier | ![]() | |
Intensity Texture | colorMultiplier | ![]() | |
Transparency | transparency | ![]() | |
Transparency Texture | transparency | ![]() | |
Emit On Back Side | doubleSided | ![]() | |
Compensate EV | compensateExposure | ![]() | |
Color*Opacity | multiplyByOpacity | ![]() | |
Color | TexCombineColor | ![]() | |
Intensity | TexCombineColor | ![]() | |
Transparency | TexCombineColor | ||
Bump | BRDFBump | ||
Base | base_brdf | ![]() | |
Mode/Map: Bump Map Bump Texture Channel Normal Map | BRDFBump/bump_tex_color BRDFBump/bump_tex_color BRDFBump/bump_tex_color |
Amount | BRDFBump/bump_tex_mult | ||
Amount Texture | BRDFBump/bump_tex_mult_tex | ![]() | |
Delta Scale | BRDFBump/bump_delta_scale | ![]() |
Maps
Native Name | V-Ray Plugin Name | Support | Note | |
Bulge | TexBulge | ![]() | Not supported in bump mapping | |
Checker | TexChecker | ![]() | Not supported in bump mapping | |
Cloth | TexCloth | ![]() | Not supported in bump mapping | |
Grid | TexGrid | ![]() | Not supported in bump mapping | |
Leather | TexLeather | ![]() | Not supported in bump mapping | |
Tiles | TexTiles | ![]() | Not supported in bump mapping | |
UVW | TexUVW | ![]() | ||
Water | TexWater | ![]() | ||
Cellular | TexCellular | ![]() | Not supported in bump mapping | |
Granite | TexGranite | ![]() | Not supported in bump mapping | |
Marble | TexMarble | ![]() | Not supported in bump mapping | |
Noise A | TexNoise | ![]() | Not supported in bump mapping | |
Noise B | TexNoiseMax | ![]() | Not supported in bump mapping | |
Rock | TexRock | ![]() | Not supported in bump mapping | |
Smoke | TexSmoke | ![]() | Not supported in bump mapping | |
Speckle | TexSpeckle | ![]() | Not supported in bump mapping | |
Splat | TexSplat | ![]() | Not supported in bump mapping | |
Stucco | TexStucco | ![]() | Not supported in bump mapping | |
Bitmap | TexBitmap | ![]() | ||
Color | TexAColor | ![]() | ||
Gradient | TexRamp | ![]() | Not supported in bump mapping | |
Sky | TexSky | ![]() | ||
Temperature | TexTemperature | ![]() | ||
Curvature | TexCurvature | ![]() | ||
Dirt | TexDirt | ![]() | ||
Egdes | TexEdges | Partial | 'Color' parameters only Not supported in bump mapping | |
Falloff | TexFalloff | ![]() | Not supported in bump mapping | |
Fresnel | TexFresnel | ![]() | Not supported in bump mapping | |
Color Correction | ColorCorrection | ![]() | Not supported in bump mapping | |
Bezier Curve | TexBezierCurveColor | ![]() | Not supported in bump mapping | |
Mix (Map) | TexMix | ![]() | Not supported in bump mapping | |
Mix (Operator) | TexCompMax | ![]() | Not supported in bump mapping | |
Mix (Value) | TexBlend | ![]() | Not supported in bump mapping | |
Multi-Sub | TexMulti | ![]() | Not supported in bump mapping | |
Simple Mix | TexCombineColor | ![]() | Not supported in bump mapping | |
Spline Curve | TexRemap | ![]() | Not supported in bump mapping | |
Tri-Planar | TexTriPlanar | ![]() | Not supported in bump mapping | |
UVW Placement | ![]() |
Footnotes
1 – Opacity is rendered the same way a clipper is rendered - it is either transparent or opaque. Mid-opacity is not supported.
