This page gives information about the Lighting Analysis Render Elements component in V-Ray for Grasshopper.
width60%
The V-Ray Element Lighting Analysis component provides a visual representation of the lighting intensity in the rendered frame. It maps Illuminance and Luminance information as color gradient or a grid of measured values onto the frame.
UI Text Box
typeinfo
You can use only one Lighting Analysis element at a time.
Lighting Analysis render element is explained in detail on the linked page.
width5%
10%
width35%25%
 Image RemovedImage Added
Input Parameters
Legend (Boolean) – When enabled, shows a legend of the false colors at the bottom of the render.
Output Parameters
Element (Generic Data) – V-Ray Lighting Analysis render element.
Example
width50%
Example scenario of how to use the Lighting Analysis element.
width5%
width45%
Result in the VFB.
