Floatingpagetoc
width25%
width50%
UI Button
colororange
newWindowtrue
icondownload
titleDownload the Corona 10 Benchmark
urlhttps://corona-renderer.com/benchmark
width25%
What is the Corona 10 Benchmark?
The Corona Benchmark is an application based on the Corona 10 rendering core which measures your system performance by rendering a scene with Corona 10 without having to run (or even install) any other software. It can be used to measure how well your system performs when rendering with Corona and you can compare your score with other users' results to make sure your hardware is running as at its full capacity or just for fun!
Some other uses include:
Fancy Bullets
typecircle
  • Comparing what improvements (if any) result from changing something about your hardware, BIOS settings, or Operating System settings
  • Making an informed decision on what hardware to buy by making sure it gives you a notable performance improvement
  • Stress testing the machine to make sure that the cooling can keep up with your CPU when it is hard at work (via command console)
Where to find the Corona 10 Benchmark?
Click the link below to download the Corona 10 Benchmark.
UI Text Box
typeinfo
 There is no installation or license activation required, but please read the license files included in the archive.
UI Button
colororange
newWindowtrue
icondownload
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
idbenchbuttons
aligncenter
classcoronatabs
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkUsing Corona Benchmark
Using the Corona Benchmark
Textboxcard
CardPageLinkThe Scores Page
The Scores Page
Textboxcard
PageToIncludeInstallation
CardPageLinkFAQ
FAQ
Textboxcard
PageToIncludeGetting Started
CardPageLinkCommand-Line Options
