Category
MtlX Shader Name
Node Name
USD id
Support
Adjustment
MtlX Adjust as HSV
mtlxhsvadjust
ND_hsvadjust
(tick)
MtlX Color Correct
mtlxcolorcorrect
ND_colorcorrect
(tick)
MtlX Contrast
mtlxcontrast
ND_contrast
(tick)
MtlX Curveadjust
mtlxcurveadjust
ND_curveadjust
(error)
MtlX HSV to RGB
mtlxhsvtorgb
ND_hsvtorgb
(tick)
MtlX Luminance
mtlxluminance
ND_luminance
(tick)
MtlX Range
mtlxrange
ND_range
(tick)
MtlX Remap
mtlxremap
ND_remap
(tick)
MtlX RGB to HSV
mtlxrgbtohsv
ND_rgbtohsv
(tick)
MtlX Saturate
mtlxsaturate
ND_saturate
(tick)
Application
MtlX Frame
mtlxframe
ND_frame_float
(tick)
MtlX Time
mtlxtime
ND_time_float
(tick)
Channel
MtlX Combine2
mtlxcombine2
ND_combine2
(tick)
MtlX Combine3
mtlxcombine3
ND_combine3
(tick)
MtlX Combine4
mtlxcombine4
ND_combine4
(tick)
MtlX Convert
mtlxconvert
ND_convert
(tick)
MtlX Extract
mtlxextract
ND_extract
(tick)
MtlX Separate2
mtlxseparate2
ND_separate2
(tick)
MtlX Separate Color 3
mtlxseparate3c
ND_separate3
(tick)
MtlX Separate Vector 3
mtlxseparate3v
ND_separate3
(tick)
MtlX Separate Color 4
mtlxseparate4c
ND_separate4
(tick)
MtlX Separate Vector 4
mtlxseparate4v
ND_separate4
(tick)
MtlX Swizzle
mtlxswizzle
ND_swizzle
(tick)
Compositing
MtlX Burn
mtlxburn
ND_burn
(tick)
MtlX Difference
mtlxdifference
ND_difference
(tick)
MtlX Disjoint Over
mtlxdisjointover
ND_disjointover
(tick)
MtlX Dodge
mtlxdodge
ND_dodge
(error)
MtlX In
mtlxin
ND_in
(tick)
MtlX Inside
mtlxinside
ND_inside
(tick)
MtlX Mask
mtlxmask
ND_mask
(tick)
MtlX Matte
mtlxmatte
ND_matte
(tick)
MtlX Minus
mtlxminus
ND_minus
(tick)
MtlX Mix
mtlxmix
ND_mix
(tick)
MtlX Out
mtlxout
ND_out
(tick)
MtlX Outside
mtlxoutside
ND_outside
(tick)
MtlX Over
mtlxover
ND_over
(tick)
MtlX Overlay
mtlxoverlay
ND_overlay
(tick)
MtlX Plus
mtlxplus
ND_plus
(tick)
MtlX Premult
mtlxpremult
ND_premult
(tick)
MtlX Screen
mtlxscreen
ND_screen
(tick)
MtlX Un-Premult
mtlxunpremult
ND_unpremult
(tick)
Conditional
MtlX If Equal
mtlxifequal
ND_ifequal
(tick)
MtlX If Greater
mtlxifgreater
ND_ifgreater
(tick)
MtlX If Greater or Equal
mtlxifgreatereq
ND_ifgreatereq
(tick)
MtlX Switch
mtlxswitch
ND_switch
(tick)
Convolution2D
MtlX Blur
mtlxblur
(tick)
MtlX Height to Normal
mtlxheighttonormal
ND_heighttonormal
(tick)
Geometric
MtlX Bitangent
mtlxbitangent
ND_bitangent
(error)
MtlX Geometry Color
mtlxgeomcolor
ND_geomcolor
(tick)
MtlX Geometry Property Value
mtlxgeompropvalue
ND_geompropvalue
(tick)
MtlX Normal
mtlxnormal
ND_normal_vector3
(tick)
MtlX Position
mtlxposition
ND_position_vector3
(tick)
MtlX Tangent
mtlxtangent
ND_tangent_vector3
(tick)
MtlX Texcoord
mtlxtexcoord
ND_texcoord_vector3
(tick)
Global
MtlX Ambient Occlusion
mtlxambientocclusion
ND_ambientocclusion_float
(error)
Houdini
MtlX Bias
hmtlxbias
ND_hmtlxbias_float
(error)
MtlX Facing Ratio
hmtlxfacingratio
ND_hmtlxfacingratio_float
(error)
MtlX Gain
hmtlxgain
ND_hmtlxgain_float
(error)
MtlX Hcatmullrom
hmtlxhcatmullrom
ND_hcatmullrom
(error)
MtlX Hinvlinear
hmtlxhinvlinear
ND_hinvlinear_float
(tick)
MtlX Huniformcubic
hmtlxhuniformcubic
ND_huniformcubic
(tick)
MtlX Huniformramp
hmtlxhuniformramp
ND_huniformramp
(tick)
Light
MtlX Directional Light
mtlxdirectional_light
(error)
MtlX Point Light
mtlxpoint_light
(error)
MtlX Spot Light
mtlxspot_light
(error)
Material
MtlX Surface Material
mtlxsurfacematerial
(error)
MtlX Volume Material
mtlxvolumematerial
(error)
Procedural
MtlX Color Cubic Ramp
hmtlxcubicrampc
(tick)
MtlX Color Ramp
hmtlxrampc
(tick)
MtlX Constant
mtlxconstant
ND_constant
(tick)
MtlX Float Cubic Ramp
hmtlxcubicrampf
(tick)
MtlX Float Ramp
hmtlxrampf
(tick)
MtlX Random Float
mtlxrandomfloat
(tick)
Procedural2D
MtlX Cell Noise 2D
mtlxcellnoise2d
ND_cellnoise2d_float
(error)
MtlX Checkerboard
mtlxcheckerboard
(tick)
MtlX Circle
mtlxcircle
(tick)
MtlX Circles2D
hmtlxcircles2d
(error)
MtlX Cloverleaf
mtlxcloverleaf
(tick)
MtlX Crosshatch
mtlxcrosshatch
(error)
MtlX Grid
mtlxgrid
(tick)
MtlX Hexagon
mtlxhexagon
(tick)
MtlX Line
mtlxline
(tick)
MtlX Noise2D
mtlxnoise2d
ND_noise2d
(tick)
MtlX Ramp4
mtlxramp4
ND_ramp4
(tick)
MtlX Ramplr
mtlxramplr
ND_ramplr
(tick)
MtlX Ramptb
mtlxramptb
ND_ramptb
(tick)
MtlX Splitlr
mtlxsplitlr
ND_splitlr
(tick)
MtlX Splittb
mtlxsplittb
ND_splittb
(tick)
MtlX Tiled Circles
mtlxtiledcircles
(tick)
MtlX Tiled Cloverleafs
mtlxtiledcloverleafs
(tick)
MtlX Tiled Hexagons
mtlxtiledhexagons
(tick)
MtlX Unified Noise 2D
mtlxunifiednoise2d
(tick)
MtlX Worley Noise 2D
mtlxworleynoise2d
ND_worleynoise2d
(tick)
Procedural3D
MtlX Cell Noise 3D
mtlxcellnoise3d
ND_cellnoise3d_float
(tick)
MtlX Fractal3D
mtlxfractal3d
ND_fractal3d
Partial
MtlX Noise3D
mtlxnoise3d
ND_noise3d
(tick)
MtlX Random Color
mtlxrandomcolor
ND_randomcolor
(tick)
MtlX Unified Noise 3D
mtlxunifiednoise3D
(tick)
MtlX Worley Noise 3D
mtlxworleynoise3d
ND_worleynoise3d
(tick)
Texture2D
MtlX Image
mtlximage
ND_image
Partial
(only file, texcoord)
MtlX Tiled Image
mtlxtiledimage
ND_tiledimage
Partial
(only file, texcoord, uvtiling, uvoffset)
Texture3D
MtlX Triplanar Projection
mtlxtriplanarprojection
ND_triplanarprojection
(error)(tick)
Math
MtlX Absval
mtlxabsval
ND_absval
(tick)
MtlX Add
mtlxadd
ND_add
(tick)
MtlX Array Append
mtlxarrayappend
ND_arrayappend
(error)
MtlX Asin
mtlxasin
ND_asin_float
(error)
MtlX Atan2
mtlxatan2
ND_atan2_float
(tick)
MtlX Ceil
mtlxceil
ND_ceil_float
(tick)
MtlX Clamp
mtlxclamp
ND_clamp
(tick)
MtlX Cos
mtlxcos
ND_cos
(tick)
MtlX Cross Product
mtlxcrossproduct
ND_crossproduct_vector3
(tick)
MtlX Distance
mtlxdistance
(tick)
MtlX Divide
mtlxdivide
ND_divide
(tick)
MtlX Dot Product
mtlxdotproduct
ND_dotproduct_vector3
(tick)
MtlX Exp
mtlxexp
ND_exp
(error)
MtlX Floor
mtlxfloor
ND_floor
(tick)
MtlX Invert
mtlxinvert
ND_invert
(tick)
MtlX Ln
mtlxln
ND_ln
(tick)
MtlX Magnitude
mtlxmagnitude
ND_magnitude
(tick)
MtlX Max
mtlxmax
ND_max
(tick)
MtlX Min
mtlxmin
ND_min
(tick)
MtlX Modulo
mtlxmodulo
ND_modulo
(tick)
MtlX Multiply
mtlxmultiply
ND_multiply
(tick)
MtlX Normalize
mtlxnormalize
ND_normalize
(tick)
MtlX Power
mtlxpower
ND_power
(tick)
MtlX Sign
mtlxsign
ND_sign
(tick)
MtlX Sin
mtlxsin
ND_sin
(error)
MtlX Sqrt
mtlxsqrt
ND_sqrt
(tick)
MtlX Subtract
mtlxsubtract
ND_subtract
(tick)
MtlX Tan
mtlxtan
ND_tan
(tick)
MtlX Transform Matrix
mtlxtransformmatrix
ND_transformmatrix
(tick)
MtlX Transform Normal
mtlxtransformnormal
ND_transformnormal_vector3
(error)
MtlX Transform Point
mtlxtransformpoint
ND_transformpoint_vector3
(error)
MtlX Transform Vector
mtlxtransformvector
ND_transformvector_vector3
(error)
Pbr
MtlX Standard Surface
mtlxstandard_surface
(tick)
Shader
MtlX Convert
mtlxconvert
(error)
MtlX Surface Unlit
mtlxsurface_unlit
(tick)
