This page provides information on MaterialX (mtlx) support.
V-Ray's implementation of MaterialX allows you to render MaterialX nodes encoded in USD with VRayScene-USD. The implementation is a mix of direct translation to V-Ray through a mapping file and custom code. Custom V-Ray plugins share the code and make graphs more efficient. The MaterialX graphs are rendered within Hydra.
Utilize the MaterialX nodes within the standard mtlx workflow in Solaris.
Instead of adding sublayers of mtlx materials, you can reference them with a Reference LOP.
Set the Reference file to the file path of the mtlx file on disk, and select the specific material to load in through the Reference primitive submenu.
Then use an Assign Material LOP to assign the referenced mtlx material to a USD prim.
For more information about alternative workflows for referencing and creating mtlx materials, as well as information about the different types of mtlx nodes, refer to the Solaris documentation.
Category | MtlX Shader Name | Node Name | USD id | Support |
Adjustment | MtlX Adjust as HSV | mtlxhsvadjust | ND_hsvadjust | |
MtlX Color Correct | mtlxcolorcorrect | ND_colorcorrect | ||
MtlX Contrast | mtlxcontrast | ND_contrast | ||
MtlX Curveadjust | mtlxcurveadjust | ND_curveadjust | ||
MtlX HSV to RGB | mtlxhsvtorgb | ND_hsvtorgb | ||
MtlX Luminance | mtlxluminance | ND_luminance | ||
MtlX Range | mtlxrange | ND_range | ||
MtlX Remap | mtlxremap | ND_remap | ||
MtlX RGB to HSV | mtlxrgbtohsv | ND_rgbtohsv | ||
MtlX Saturate | mtlxsaturate | ND_saturate | ||
MtlX Smoothstep | mtlxsmoothstep | ND_smoothstep | ||
Application | MtlX Frame | mtlxframe | ND_frame_float | |
MtlX Time | mtlxtime | ND_time_float | ||
Channel | MtlX Combine2 | mtlxcombine2 | ND_combine2 | |
MtlX Combine3 | mtlxcombine3 | ND_combine3 | ||
MtlX Combine4 | mtlxcombine4 | ND_combine4 | ||
MtlX Convert | mtlxconvert | ND_convert | ||
MtlX Extract | mtlxextract | ND_extract | ||
MtlX Separate2 | mtlxseparate2 | ND_separate2 | ||
MtlX Separate Color 3 | mtlxseparate3c | ND_separate3 | ||
MtlX Separate Vector 3 | mtlxseparate3v | ND_separate3 | ||
MtlX Separate Color 4 | mtlxseparate4c | ND_separate4 | ||
MtlX Separate Vector 4 | mtlxseparate4v | ND_separate4 | ||
MtlX Swizzle | mtlxswizzle | ND_swizzle | ||
Compositing | MtlX Burn | mtlxburn | ND_burn | |
MtlX Difference | mtlxdifference | ND_difference | ||
MtlX Disjoint Over | mtlxdisjointover | ND_disjointover | ||
MtlX Dodge | mtlxdodge | ND_dodge | ||
MtlX In | mtlxin | ND_in | ||
MtlX Inside | mtlxinside | ND_inside | ||
MtlX Mask | mtlxmask | ND_mask | ||
MtlX Matte | mtlxmatte | ND_matte | ||
MtlX Minus | mtlxminus | ND_minus | ||
MtlX Mix | mtlxmix | ND_mix | ||
MtlX Out | mtlxout | ND_out | ||
MtlX Outside | mtlxoutside | ND_outside | ||
MtlX Over | mtlxover | ND_over | ||
MtlX Overlay | mtlxoverlay | ND_overlay | ||
MtlX Plus | mtlxplus | ND_plus | ||
MtlX Premult | mtlxpremult | ND_premult | ||
MtlX Screen | mtlxscreen | ND_screen | ||
MtlX Un-Premult | mtlxunpremult | ND_unpremult | ||
Conditional | MtlX If Equal | mtlxifequal | ND_ifequal | |
MtlX If Greater | mtlxifgreater | ND_ifgreater | ||
MtlX If Greater or Equal | mtlxifgreatereq | ND_ifgreatereq | ||
MtlX Switch | mtlxswitch | ND_switch | ||
Convolution2D | MtlX Blur | mtlxblur | ||
MtlX Height to Normal | mtlxheighttonormal | ND_heighttonormal | ||
Geometric | MtlX Bitangent | mtlxbitangent | ND_bitangent | |
MtlX Geometry Color | mtlxgeomcolor | ND_geomcolor | ||
MtlX Geometry Property Value | mtlxgeompropvalue | ND_geompropvalue | ||
MtlX Normal | mtlxnormal | ND_normal_vector3 | ||
MtlX Position | mtlxposition | ND_position_vector3 | ||
MtlX Tangent | mtlxtangent | ND_tangent_vector3 | ||
MtlX Texcoord | mtlxtexcoord | ND_texcoord_vector3 | ||
Global | MtlX Ambient Occlusion | mtlxambientocclusion | ND_ambientocclusion_float | |
Houdini | MtlX Bias | hmtlxbias | ND_hmtlxbias_float | |
MtlX Facing Ratio | hmtlxfacingratio | ND_hmtlxfacingratio_float | ||
MtlX Gain | hmtlxgain | ND_hmtlxgain_float | ||
MtlX Hcatmullrom | hmtlxhcatmullrom | ND_hcatmullrom | ||
MtlX Hinvlinear | hmtlxhinvlinear | ND_hinvlinear_float | ||
MtlX Huniformcubic | hmtlxhuniformcubic | ND_huniformcubic | ||
MtlX Huniformramp | hmtlxhuniformramp | ND_huniformramp | ||
Light | MtlX Directional Light | mtlxdirectional_light | ||
MtlX Point Light | mtlxpoint_light | |||
MtlX Spot Light | mtlxspot_light | |||
Material | MtlX Surface Material | mtlxsurfacematerial | ||
MtlX Volume Material | mtlxvolumematerial | |||
Procedural | MtlX Color Cubic Ramp | hmtlxcubicrampc | ||
MtlX Color Ramp | hmtlxrampc | |||
MtlX Constant | mtlxconstant | ND_constant | ||
MtlX Float Cubic Ramp | hmtlxcubicrampf | |||
MtlX Float Ramp | hmtlxrampf | |||
Procedural2D | MtlX Cell Noise 2D | mtlxcellnoise2d | ND_cellnoise2d_float | |
MtlX Noise2D | mtlxnoise2d | ND_noise2d | ||
MtlX Ramp4 | mtlxramp4 | ND_ramp4 | ||
MtlX Ramplr | mtlxramplr | ND_ramplr | ||
MtlX Ramptb | mtlxramptb | ND_ramptb | ||
MtlX Splitlr | mtlxsplitlr | ND_splitlr | ||
MtlX Splittb | mtlxsplittb | ND_splittb | ||
MtlX Worley Noise 2D | mtlxworleynoise2d | ND_worleynoise2d | ||
Procedural3D | MtlX Cell Noise 3D | mtlxcellnoise3d | ND_cellnoise3d_float | |
MtlX Fractal3D | mtlxfractal3d | ND_fractal3d | ||
MtlX Noise3D | mtlxnoise3d | ND_noise3d | ||
MtlX Random Color | mtlxrandomcolor | ND_randomcolor | ||
MtlX Worley Noise 3D | mtlxworleynoise3d | ND_worleynoise3d | ||
Texture2D | MtlX Image | mtlximage | ND_image | |
MtlX Tiled Image | mtlxtiledimage | ND_tiledimage | ||
Texture3D | MtlX Triplanar Projection | mtlxtriplanarprojection | ND_triplanarprojection | |
Math | MtlX Absval | mtlxabsval | ND_absval | |
MtlX Acos | mtlxacos | ND_acos | ||
MtlX Add | mtlxadd | ND_add | ||
MtlX Array Append | mtlxarrayappend | ND_arrayappend | ||
MtlX Asin | mtlxasin | ND_asin_float | ||
MtlX Atan2 | mtlxatan2 | ND_atan2_float | ||
MtlX Ceil | mtlxceil | ND_ceil_float | ||
MtlX Clamp | mtlxclamp | ND_clamp | ||
MtlX Cos | mtlxcos | ND_cos | ||
MtlX Cross Product | mtlxcrossproduct | ND_crossproduct_vector3 | ||
MtlX Determinant | mtlxdeterminant | ND_determinant | ||
MtlX Divide | mtlxdivide | ND_divide | ||
MtlX Dot Product | mtlxdotproduct | ND_dotproduct_vector3 | ||
MtlX Exp | mtlxexp | ND_exp | ||
MtlX Floor | mtlxfloor | ND_floor | ||
MtlX Invert | mtlxinvert | ND_invert | ||
MtlX Invert Matrix | mtlxinvertmatrix | |||
MtlX Ln | mtlxln | ND_ln | ||
MtlX Magnitude | mtlxmagnitude | ND_magnitude | ||
MtlX Max | mtlxmax | ND_max | ||
MtlX Min | mtlxmin | ND_min | ||
MtlX Modulo | mtlxmodulo | ND_modulo | ||
MtlX Multiply | mtlxmultiply | ND_multiply | ||
MtlX Normalize | mtlxnormalize | ND_normalize | ||
MtlX Normalmap | mtlxnormalmap | ND_normalmap | ||
MtlX Place2D | mtlxplace2d | ND_place2d_vector2 | ||
MtlX Power | mtlxpower | ND_power | ||
MtlX Rotate2D | mtlxrotate2d | ND_rotate2d_vector2 | ||
MtlX Rotate3D | mtlxrotate3d | ND_rotate3d_vector3 | ||
MtlX Sign | mtlxsign | ND_sign | ||
MtlX Sin | mtlxsin | ND_sin | ||
MtlX Sqrt | mtlxsqrt | ND_sqrt | ||
MtlX Subtract | mtlxsubtract | ND_subtract | ||
MtlX Tan | mtlxtan | ND_tan | ||
MtlX Transform Matrix | mtlxtransformmatrix | ND_transformmatrix | ||
MtlX Transform Normal | mtlxtransformnormal | ND_transformnormal_vector3 | ||
MtlX Transform Point | mtlxtransformpoint | ND_transformpoint_vector3 | ||
MtlX Transform Vector | mtlxtransformvector | ND_transformvector_vector3 | ||
MtlX Transpose | mtlxtranspose | ND_transpose | ||
Pbr | MtlX Blackbody | mtlxblackbody | ND_blackbody |
The following functions are supported in Solaris:
