Animation Keys – Deletes all animation keys in the scene.
Animation Layers – Deletes all animation layers in the scene.
Bitmap Chache Cache – Frees up all the memory used by the image file bitmap caches. This is useful if memory is fragmented with a lot of different bitmaps and you want to have just ones currently active reloaded.
UI Text Box
type
warning
This operation is not undoable.
Block/Style Parent Object –Deletes all nodes containing Block/Style parent object in the scene.
Empty Layers – Deletes – Deletes all empty layers in the scene.
MAXScript Memory – Excludes – Executes MAXScript's garbage collector, potentially freeing up some memory MAXScript was using.
UI Text Box
type
warning
Note Tracks –Deletes all note tracks in the scene.
All Retimers –Deletes all retimers in the scene.
All Retimers With No Markers – Deletes all retimers with no markers in the scene, i.e. empty retimers.
UI Text Box
type
note
This operation is slower than deleting All Retimers.
Particle View Objects –Deletes all Particle View related helpers and objects.
Undo/Redo Stack –Empties the Undo/Redo stack.
UI Text Box
type
warning
Unresolved XRefs –Deletes all unresolved XRef objects and XRef scenes in the scene.
UI Text Box
type
warning
Select All – Selects all Scene Cleaner checkboxes.
Select None – Deselects all Scene Cleaner checkboxes.
