Floatingpagetoc |
What is Chaos Scans?
Chaos Scans is a scanning technology which converts real-world materials such as textiles, plastic, paint, and metal into digital materials. These can be used in 3D software tools to create photorealistic computer-generated images and animations.
Why should I use Chaos Scans?
Recreating materials from the real world in 3D software can be a painstaking process, especially if they exhibit complex behaviors under certain lighting conditions. Chaos Scans solves this issue by capturing photorealistic, tileable materials with an unmatched level of quality and accuracy. Chaos Scans can be used by anyone who wants to bring new levels of realism to their imagery and animation, from freelance artists to large studios. At the moment, it works with V-Ray for 3ds Max, V-Ray for Maya, V-Ray for SketchUp, V-Ray for Rhino, V-Ray for Revit, V-Ray for Houdini, V-Ray for Cinema 4D, Corona for 3ds Max, and Corona for Cinema 4D.
How are Scans materials different?
Scans materials can be dragged and dropped onto geometry. They automatically resolve their behavior under different lighting conditions, without any customization.
Can I modify Scans materials?
Since Scans is aimed at accurately reproducing reality, the Scans materials do not allow the same level of control as custom-built materials. The .vrscans file contains a complete data set, so there are no separate texture maps.
Do Scans materials support render elements?
For a list of supported Render Elements in V-Ray for Cinema 4D, follow the link.
What kind of materials can be scanned?
Fancy Bullets | ||
What is Scans Service?
If you are working with tight deadlines and need to create many complex 3D materials for automotive, product design or fashion projects, then the Scans service is the perfect match for you. We scan your physical material samples to create a highly accurate, ultra-photorealistic digital material for use in 3D projects.
How does the Scans Scanning Service work?
We understand that materials may be proprietary or copyrighted, so all samples are promptly returned to the client.
*Additional courier fees may apply
Yes. Note that particular materials can't be represented well as diffuse/specular mixture, therefore the material recreation via maps is less realistic.
What is Chaos Scans plugin?
To continue using the Scans materials and the Chaos Scans Library, the user will have to maintain their subscription on an annual basis.
What is Chaos Scans Library?
The library is accessible to all Scans license holders.
How to access Chaos Scans?
Chaos Scans is provided with the installation of V-Ray or Corona.
Where to find information on costs?
