This page guides users who are connecting remotely to a Premium Chaos License .
UI Text Box
typewarning
This page is for users connecting remotely
This page explains how users within a network can connect remotely to a shared Premium license that is already set up. If you are just setting up a shared license, please see the Admin Workflow page.
The Premium License can be used locally, similar to the Solo License. If you would like to perform a local setup, see the Solo User page.
or a Chaos Enscape 4.1 Floating license.
What are Premium and Floating Licenses
Premium and Floating Licenses can be shared between multiple users and devices, or they can be used locally - similar to the Solo and Fixed Licenses.
The Premium License can also be shared between multiple users and devices. When doing a shared setup for a Premium or Floating license, the license still holder needs to be installed install the license locally on at least one machine in the network. Installing the license happens automatically when you perform a default Chaos product installation. If you only need to install the License Server application separately, see the Installation page. This machine can use the license, but it also serves as a connection point for others to connect to the license.
Fancy Bullets
typecircle
  • The license holder can give out their IP address to others in the local network, and they can connect using the remote license setup.
  • The license holder can assign licenses through the my.chaos portal. This method allows the license holder to manage the licenses centrally; no other user can adjust the license settings.
Using a Premium or Floating license locally requires installing your Chaos product with the "Local License" setting in the installer and logging in with your Chaos account credentials when prompted.
Fancy Bullets
typecircle
  • If you are the license holder, you can install the license locally on your machine. In this case, follow the Solo and Fixed Licenses workflow.
  • If you are not the license holder, ask an Administrator to assign a license to you via the my.chaos portal. You can see how on the My Chaos Portal Guide.
Keep in mind that a single license can be used by a single user at a time. You need to acquire add more licenses if you wish multiple users to work at the same time.
UI Text Box
typeinfo
To create a setup for sharing Premium or Floating licenses, please see the Admin Workflow page.
UI Button
colorblue
newWindowtrue
icondownload
titleGet a Chaos License
urlhttps://www.chaos.com/pricing
UI Text Box
typetip
Corona Activation
If you are activating a Chaos License for Corona, please see the Activating Corona for 3ds Max or Activating Corona for Cinema 4D pages, depending on your integration.
Enscape Activation
When connecting remotely to a Floating License for Enscape 4.1, follow the instructions on this page. For a step-by-step guide specifically for Enscape, see the Enscape First Steps article. If you are using Enscape 4.0 or older, see the Enscape License Activation article.
Activating the License
width50%
If you are connecting to a Premium or Floating License, which is not located on your machine, you are using a Remote Licensing setup. The remote license server is typically managed by your IT administrator or license holder and activated with your company the Chaos account that holds your the Premium or Floating licenses.
Fancy Bullets
typecircle
  • Ask your license administrator for the License Serverholder for their machine's IP address.
  • Download your Chaos product(s) and run the installation wizard. After accepting the End User License Agreement, you need to select the Advanced installation option.
width5%
width45%
Example screenshot
width50%
Fancy Bullets
typecircle
  • At the Licensing step, select Remote. In the Primary License Server field, type the server IP address that your license administrator holder gave you. At the end, add the :30304 port.
  • Continue to finish the installation. As long as your license administrator's license is active, you can use the remotely shared license.
width5%
width45%
Example screenshot
