1.0.7.41
Fancy Bullets
typecircle
  • Add support for 8 bit DPX files
1.0.7.40
Fancy Bullets
typecircle
  • Display OpenColorIO settings dialog on .ocio import
  • Add "Apply Default OCIO Configuration" to lookup table menu
1.0.7.39
Fancy Bullets
typecircle
  • Support .ocio config files as lookup tables, using Import... and
    --lookup_table=my_config.ocio or
    --lookup_table=my_config.ocio,color_space,display,view
1.0.7.38
Fancy Bullets
typecircle
  • When a layer is rescanned for new frames and automatic preload is enabled, preload the modified frames
1.0.7.37
Fancy Bullets
typecircle
  • Fix handling of grayscale JPEG
1.0.7.36
Fancy Bullets
typecircle
  • Increase AIVF playback performance
1.0.7.35
Fancy Bullets
typecircle
  • Support more .3dl variations
1.0.7.34
Fancy Bullets
typecircle
  • Fix support for alternate license servers
1.0.7.33
Fancy Bullets
typecircle
  • Add support for packed 12 bit DPX files
1.0.7.32
Fancy Bullets
typecircle
  • Add both DWAA and DWAB compression; change default quality to 90
  • Add write support for AIVF
