« Previous Version 2 Current »
1.0.7.32
  • Add both DWAA and DWAB compression; change default quality to 90
  • Add write support for AIVF
1.0.7.31
  • Update LUTs to work consistently in log space regardless of input format
  • Add support for LUT_1D_INPUT_RANGE, LUT_3D_INPUT_RANGE
1.0.7.30
  • Fix crash with Next/Previous Image when caching was disabled
1.0.7.29
  • Add support for bottom-up DPX files.
1.0.7.28
  • Add Disable Caching Globally instead of Disable Caching by Default
  • Add Side by Side (Full), (Half) in Source > Target View
1.0.7.27
  • Enable saving .mov with alpha
  • Recognize .vri as a VRIMG extension
  • Add option for parallel (multithreaded) sequence preload
1.0.7.26
  • Add support for field expressions on the command line
  • Add support for --name+=value, --name-=value
1.0.7.25
  • Update OpenEXR to 2.2.0.
  • Add default filename to Save Frame As dialog
1.0.7.24
  • Add Copy Frame as Image
  • Add a second frame/timecode indicator
  • Add default filename to Save Layer As dialog
1.0.7.23
  • Add --print_commands, which prints all commands
  • Improve interactive performance when caching is disabled
1.0.7.22
  • Add read support for .aivf files
  • Track metadata viewer state separately in full screen
  • Change default audio sample rate from 44100 to 48000
  • Declare DPI awareness to avoid scaling
1.0.7.21
  • Load audio in background
1.0.7.20
  • Fix "Set Checkerboard as Default"
  • Write 444 .jpeg files instead of 420
1.0.7.19
  • Add "layer_scan_for_new_versions" command
1.0.7.18
  • Use EXR part names
1.0.7.17
  • Add support for multipart EXR files
1.0.7.16
  • Fix crash when "Frame from File Name" was selected on the info bar and the time slider was outside the selected layer
1.0.7.15
  • Add metadata viewer (hotkey M)
  • Change the flip hotkey to F
  • Read metadata from R3D files
  • Read metadata from EXR files
  • Read metadata from DPX files
  • Fix --global:selection
1.0.7.14
  • Fix text layer center/right alignment
1.0.7.13
  • Add support for .MX .MY .MZ layers in EXR files
1.0.7.12
  • Add //-style comment support in pdpcmd files
  • Fix "invalid option" errors on --attach, --attach_nf
  • Automatically enable console output under Windows
1.0.7.11
  • Enable "Duplicate" in menu on multiple selection
1.0.7.10
  • Add --stdout=, --stderr=, --print= options
  • Print diagnostic messages to stderr
  • Add support for %{scope:field}, --scope:field=value
  • Add --print_field=field, --print_fields=scope (scope can be global, env, var, selected, or a layer set)
  • Add support for id(5) in a layer set
1.0.7.9
  • Add support for secondary timecode
  • Read timecode fron DNG files
  • Read timecode from MOV files
  • Write timecode to MOV files
  • Write timecode when saving mask
1.0.7.8
  • Improve DNG import performance and dynamic range
  • Add support for WAVE_FORMAT_EXTENSIBLE PCM .wav files
1.0.7.7
  • Set initial directory of LUT import
  • Add Undo Reset, ctrl+double-click to edit fields
  • Add --temperature=K
  • Fix temperature not being exported, copied and pasted
  • Read DNG images as floating point
  • Add support for non-ASCII DNG file names
1.0.7.6
  • Add --export_composition_as=filename
1.0.7.5
  • Portability and performance improvements
1.0.7.4
  • Add support for RGBA .vrimg channels (generated by V-Ray 3.0)
1.0.7.3
  • Add temperature color control.
1.0.7.2
  • Update .nk export to handle per-channel color settings
  • Load .vrimg images as floating point
  • Load IEEE float TIFF images as floating point
1.0.7.1
  • Add per-channel exposure, brightness, contrast, hue, saturation.
