This page contains links to information about the new V-Ray release notes organized by build version numberSwarm build versions.
The links below are for the notes for each incremental release of The information about every new V-Ray Swarm build version is located below.
Build Version Notes
New in 1.4.7
- Fixed a crash with Apple M1 CPUs
New in 1.4.6
- Update some terminology in the UI
New in 1.4.5
- Rebranded icons
New in 1.4.4
- Add the utf-8-validate and bufferutil optional dependencies
- Prevent searching for the source-map-support module
- Linux installation fixes
New in 1.4.3
- Windows build installs Visual C++ Redistributable
New in 1.4.2
- Allow disabling the GPU rendering on Swarm nodes
New in 1.4.1
- Remove uploaded V-Ray versions after uninstall
- Enable manual selection of V-Ray version
- Enable custom multicast TTL configuration (in auto-discovery mode)
- Improve the configuration of environment variables
New in 1.3
- Allow the user to manually choose "master" nodes for the Swarm Cluster
- Drop the "broadcast" auto-discovery mechanism, default to multicast only
- Allow license settings changes from the installer
