« Previous Version 3 Next »
This page contains information about the new V-Ray Swarm build versions.
The information about every new V-Ray Swarm build version is located below.
Build Version Notes
New in 1.4.7
  • Fixed a crash with Apple M1 CPUs
New in 1.4.6
  • Update some terminology in the UI
New in 1.4.5
  • Rebranded icons
New in 1.4.4
  • Add the utf-8-validate and bufferutil optional dependencies
  • Prevent searching for the source-map-support module
  • Linux installation fixes
New in 1.4.3
  • Windows build installs Visual C++ Redistributable
New in 1.4.2
  • Allow disabling the GPU rendering on Swarm nodes
New in 1.4.1
  • Remove uploaded V-Ray versions after uninstall
  • Enable manual selection of V-Ray version
  • Enable custom multicast TTL configuration (in auto-discovery mode)
  • Improve the configuration of environment variables
New in 1.3
  • Allow the user to manually choose "master" nodes for the Swarm Cluster
  • Drop the "broadcast" auto-discovery mechanism, default to multicast only
  • Allow license settings changes from the installer
