The VRayLensEffects is a render effect plugin used to simulate bloom and glare lens effects by filtering the rendered image with a filter kernel. It uses a fast multi-threaded technique to compute the result. The options can be accessed through the Vthe V-Ray frame buffer with the Open lens effects settings button.
UI Text Box | ||
The Lens Effects window can be docked or undocked from the VFB by right-clicking the Open lens effects settings button. |
Result Channel
When lens effects are applied, a new channel called effectsResult will be created in the VFB. The RGB Channel button allows users to easily toggle between the effectsResult and original RGB channel.
