This page provides some details on how to get V-Ray up and running.
UI Button | ||||||||||
Section | |||||||||||||||||
Installing V-Ray via Installer
The V-Ray installer automatically removes any previous installations. Thus, you can seamlessly upgrade from previous versions. If you experience problems, you can manually uninstall the previous versions to perform a clean install.
Tabs Container | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Licensing V-Ray
Once the Chaos License Server installation is complete, you are directed to the Chaos License Server local host (127.0.0.1:30304) in order to sign in.
UI Text Box | ||
The Chaos License Server will skip its installation process for two reasons:
For full information on the Chaos License Server options and settings, see the Licensing section of the documentation.
Loading the V-Ray Shelf
When starting V-Ray for Houdini for the first time, you need to manually load the V-Ray Shelf. From the Houdini shelf, click the plus + icon, navigate to Shelves, and select V-Ray from the list.
Anchor | ||||
Selecting a Renderer
To render with V-Ray, simply click the Render button from the V-Ray Shelf. This automatically creates a vray_renderer node in the Network Editor (if one is not already present) and launches the V-Ray Frame Buffer.
