width40%50%
V-Ray is a rendering plugin for Houdini. V-Ray offers a number of materials, textures, lights, utility nodes, volumetrics, and render elements specifically designed for а a smooth workflow.
V-Ray for Houdini includes two render engines: V-Ray and V-Ray GPU.
V-Ray is implemented in Houdini as a set of custom nodes, most notably the V-Ray Renderer node for Production rendering, and the V-Ray IPR node for Interactive rendering. V-Ray renderings display in the V-Ray Virtual Frame Buffer (VFB), which has a multitude of V-Ray specific tools for saving and comparing renderings, adding lens effects, and viewing render elements. For tools to adjust rendering quality and speed with V-Ray and V-Ray GPU, see the Renderer Node page.
width5%
55%
width45%
Image AddedImage Removed
Rendering with V-Ray
Both V-Ray and V-Ray GPU engines support Production and IPR Rendering modes. The Production Rendering mode utilizes all V-Ray's features and is intended to be used to create a clean production ready render.
UI Text Box
typetip
You can have multiple cameras in a scene with different render settings. You can also have multiple V-Ray Renderer and V-Ray Renderer IPR nodes that are configured differently. Shift+Left-click on the Render/IPR (VFB) and ROP Parm/IPR ROP Parm shelf buttons allows you to select different ROP settings. Alternatively, press Shift + Left-click on the Show VFB shelf button to open a context menu of available ROP configurations in the scene.
To switch between different camera views, open the VFB and hold click on the Render button.
UI Text Box
typenote
When rendering from the Render to Disk button in the V-Ray Renderer node, the camera specified in the Camera slot is used. When rendering from the Render/IPR (VFB) toolbar buttons or the VFB's Render button, you can override the specified camera.
Starting V-Ray Render
Make sure a camera is set. You can set several cameras in a scene and then switch between them.
Create a V-Ray Renderer node in the out Network using one of the following ways:
  • Go to Render menu > Create Render Node > V-Ray
  • ||out Network|| > V-Ray Renderer
  • Go to Render menu > Create Render Node V-Ray
To learn how to start Interactive Production Rendering (IPR), see the Interactive Rendering page.
UI Text Box
typeinfo
Note that you can have multiple V-Ray Renderer and Renderer IPR nodes with different settings in a scene.
  • In the V-Ray Shelf, click on the Render button. This initiates a render process in the VFB.
  • Go to V-Ray menu > Render > V-Ray ROP
  • In the V-Ray Shelf, click on the click the Show VFB button. Then in the VFB, click the Render button.
  • Go to V-Ray Renderer node settings and press click the Render to Disk button.
UI Text Box
typetip
If vray/vray_ipr nodes are not aren't created in the out Network, pressing clicking the Render button or Show VFB button on the V-Ray Shelf automatically creates them botha vray node. If necessary, the render settings can be configured.
Image Added
Image Removed
Viewport Rendering
Make sure vray and vray_ipr nodes are created in the out Network. Create a camera in the Scene View.
For more detailed information on how to configure the IPR settings, see the Interactive Rendering page.
Image RemovedImage Added
Fancy Bullets
typecircle
  • When rendering or exporting a .vrscene with a heavy geometry or volumes in it that are not cached in an external file, a warning displays that heavy uncashed objects may slow down the rendering till the first pixel appears.
