This page provides information on the Mtl2Sided material node.
Section | |||||
Node
Section | |||||||||||||||
Anchor | ||||
Example: Translucency
This example shows the effect of the Translucency parameter. We use a V-Ray Two Sided material with two different V-Ray Materials for the front and back sides. Note that the Multiply by Front Diffuse option is enabled.
Section | |||||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Multiply by Front Diffuse
This example shows the effect of the Multiply by Front Diffuse parameter.
Fancy Bullets | ||
