Section | |||||||||||||||
Section | |||||||||||||||||||||||||
border | true |
width | 50% |
Anchor | ||||
Anchor | ||||
Example: The Refraction Color Parameter
This example demonstrates the effect of the Refraction color parameter to produce glass materials. For the images in this example, the material is with a grey Diffuse color, white Reflection color and Fresnel option on.
Image slider | |||||||||||||||
width | 50% |
Example: The Refraction IOR Parameter
This example demonstrates the effect of the Refraction IOR parameter. Note how light bends more as the IOR deviates from 1.0. The case when the index of refraction (IOR) is 1.0 produces a transparent object. Note however, that in the case of transparent objects, it might be better to assign an opacity map to the material, rather than use refraction.
Image slider | ||||||||||||||||||||
Anchor | refractionGlossiness | refractionGlossiness |
Anchor | ||
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Section | ||
Example: The Fog Multiplier Parameter
This example demonstrates the effect of the Fog multiplier parameter. Smaller values cause less light absorption because of the fog; while higher values increase the absorption effect.
Translucency
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
