BRDFHair3 is a material that is primarily designed for rendering hair and fur.
UI Path: ||mat Network|| > V-Ray > Material > V-Ray Hair 3
Components of BRDFHair3
width50%
The material is based around three components - primary specular component, secondary specular component, and a transmission component. A diffuse component is also provided for rendering of materials made up of cloth threads or other non-translucent fibers.
The primary specular component represents light that is reflected off the outer surface of a hair strand. The secondary specular component represents light that goes through the hair strand and is reflected off the back surface. The transmission component represents light that goes through the hair strand.
The image below illustrates the meaning of the three components:
width5%
width45%
