This page provides information on the V-Ray TexFresnel node.
Section | ||||||||||||||||
Example: V-Ray Fresnel vs. Fresnel Reflections
A V-Ray Material is applied to both objects below, with different material setups. Where V-Ray Fresnel is used, the front of the object (the part that faces the camera) is much less reflective than the sides of the object. The degree of reflectivity set by V-Ray Fresnel affects both the reflected background and the reflection of the rectangular light source.
Section | |||||||||||||||||||||||
