Preview & Render Cache Path | rendinput – This is the path to the cache sequence to shown in the preview and rendered. The default is $(same_as_output), meaning the preview and render would show the caches created by the simulation, reading them from the path specified in the Output rollout. Use the button to select the path or type it manually. Phoenix has some keywords that can be used for more flexibility:
