You can download the latest official version of V-Ray for Blender from http://www.chaosgroupchaos.com with the account supplied to you by Chaos Group or your reseller.
If you experience any problems please check the Troubleshooting section.
In order to render with V-Ray, you need V-Ray for Blender, a custom build which consists of:
Additional pages in this section cover setting up Distributed Rendering.
UI Text Box | ||||
Please note, V-Ray is supported on Blender version 2.79. V-Ray for Blender 3.0 denotes the V-Ray version, which is 3.0. |
Installing V-Ray
The V-Ray installer for Blender is pretty straightforward and easy to follow and can be downloaded from the Chaos Group website (please make sure you use your login credentials to ensure access to the download links). It's recommending that before installing V-Ray, please make sure your computer meets the System Requirements for running Blender with V-Ray. If you would like a step-by-step guide, please check out the Install V-Ray for Blender page. If you run into any problems, please check out the Troubleshooting page.
