This page provides information about V-Ray supported version of platforms that can make use of Chaos Cloud rendering.
UI Text Box | ||
Each Chaos Cloud job is rendered with the latest publicly available build of the V-Ray version used to create the original scene, e.g. a scene created with V-Ray Next is rendered with the latest publicly available version of V-Ray Next. |
UI Text Box | ||
Chaos Support team provides support for the following products: - V-Ray 6 for: 3ds Max, Maya, SketchUp, Rhino, Houdini, and Cinema 4D - V-Ray 5 for: 3ds Max, Maya, Houdini, SketchUp, Rhino, Revit, and Cinema 4D All failed jobs created with earlier V-Ray versions will still be automatically refunded. However, issues with such jobs won't be investigated by the Chaos Support teams. |
Cloud Rendering Compatibility
Product Versions | V-Ray 6 | V-Ray 5 | V-Ray Next | V-Ray 3.6 | ||||||||||
Windows | Linux | macOS | Windows | Linux | macOS | Windows | Linux | macOS | Windows | Linux | macOS | |||
3ds Max® | 2018 or later | - | - | 2016 & later | - | - | 2013 - 2021 | - | - | - | - | - | ||
Maya | 2019 & later | 2019 & later | 2019 & later | 2017 & later | 2017 & later | 2017 & later | 2015 - 2021 | 2015 - 2021 | 2016.5 - 2021 | - | - | - | ||
Cinema 4D | R21 &later | - | R21 & later | R20 & later | - | R20 & later | - | - | - | R18 & later* | - | R18 & later* | ||
Houdini | - | - | 19.0, 19.5 | 19.0, 19.5 | 19.0, 19.5- | 18.5, 19.0, 19.5 | 18.5, 19.0, 19.5 | 18.5, 19.0, 19.5 | 18.5.499 & later | 18.5.499 & later | 18.5.499 & later | - | - | - |
Revit | - | - | - | 2018 & later | - | - | 2015 - 2019 | - | - | 2015 & later | - | - | ||
Rhino | v6.29.20238 & later v7.0.20314 & later | - | - | v6.29.20238 & later v7.0.20314 & later | - | - | 5.14 & later (64-bit only) 6.13.19058 & later | - | - | 5.14 & later (64-bit only) 6.6.18117 & later | - | - | ||
SketchUp | 2019 - 2022 | - | 2019 - 2022 | 2017 & later | - | 2017 & later | 2016 (64-bit) - 2020 | - | 2016 (64-bit) - 2020 | 2015 and later | - | 2015 & later | ||
Modo | - | - | - | - | - | - | 901 & later | - | 901-13 | Modo 701 (SP5) 801 (SP2 or higher) & later | - | Modo 701 (SP5) 801 (SP2 or higher) & later |
Product | V-Ray 6 | V-Ray 5 | V-Ray Next |
3ds Max® | |||
Maya | |||
Cinema 4D | |||
Houdini | |||
Revit | |||
Rhino | |||
SketchUp | |||
Modo |
