This page provides information about V-Ray supported version of platforms that can make use of Chaos Cloud rendering.
UI Text Box
typenote
Each Chaos Cloud job is rendered with the latest publicly available build of the V-Ray version used to create the original scene, e.g. a scene created with V-Ray Next is rendered with the latest publicly available version of V-Ray Next.
UI Text Box
typenote
Chaos Support team provides support for the following products:
- V-Ray 6 for: 3ds Max, Maya, SketchUp, Rhino, Houdini, and Cinema 4D
 - V-Ray 5 for: 3ds Max, Maya, Houdini, SketchUp, Rhino, Revit, and Cinema 4D
All failed jobs created with earlier V-Ray versions will still be automatically refunded. However, issues with such jobs won't be investigated by the Chaos Support teams.
Cloud Rendering Compatibility
Product VersionsV-Ray 6V-Ray 5V-Ray NextV-Ray 3.6
WindowsLinuxmacOSWindowsLinuxmacOSWindowsLinuxmacOSWindowsLinuxmacOS
3ds Max®
2018 or later
--2016 & later--2013 - 2021--
Maya2019 & later2019 & later2019 & later2017 & later2017 & later2017 & later2015 - 20212015 - 20212016.5 - 2021---
Cinema 4DR21 &later-R21 & laterR20 & later-R20 & later
--R18 & later*-R18 & later*
Houdini--19.0, 19.519.0, 19.519.0, 19.5-18.5, 19.0, 19.518.5, 19.0, 19.518.5, 19.0, 19.518.5.499 & later18.5.499 & later18.5.499 & later---
Revit---2018 & later--2015 - 2019--2015 & later--
Rhino
v6.29.20238 & later
v7.0.20314 & later
v6.29.20238 & later
 v7.0.20314 & later
5.14 & later (64-bit only)
6.13.19058 & later
--5.14 & later (64-bit only)
6.6.18117 & later
SketchUp2019 - 2022-2019 - 20222017 & later-2017 & later2016 (64-bit) - 2020-2016 (64-bit) - 20202015 and later-2015 & later
Modo------901 & later-901-13
Modo 701 (SP5)
801 (SP2 or higher) & later
Modo 701 (SP5)
ProductV-Ray 6V-Ray 5V-Ray Next
3ds Max®(tick)(tick)(error)
Maya(tick)(tick)(error)
Cinema 4D(tick)(tick)(error)
Houdini(tick)(tick)(error)
Revit(tick)(tick)(error)
Rhino(tick)(tick)(error)
SketchUp(tick)(tick)(error)
Modo(error)(error)(error)
