This page provides information about V-Ray Toon Channel in V-Ray for Houdini.
Section | |||||||||||||||||
Common Uses
The V-Ray Toon Render Element is useful for changing the appearance of a render in a compositing or image editing application. The V-Ray Toon Render Element holds a mask for the toon outlines (the toon color is not present in it).
It has an option to invert its output so instead of white lines on a black background, we can get the opposite. It also supports opacity set from the toon effect. See how V-Ray Toon looks with inverted colors.
Section | |||||||||||||||||||||||||||||||||||
When V-Ray materials reflections and refractions are not set to Affect All channels, V-Ray Toon is not applied to them. See how the RE looks when that mode is set and when it is not. In this example, Invert color is enabled.
Before after | ||||||||||
V-Ray Toon is often used for creating cartoon-like renders. This can be achieved my Multiplying it by the V-Ray Diffuse Render Element in a compositing or editing software.
Fancy Bullets | ||
