- The Generate diffuse, Diffuse subdivs, and Diffuse multiplier options are removed from the UI.
- In earlier V-Ray versions, matte objects always show the background. Since V-Ray 6, however, the matte objects show the V-Ray Dome light instead of the background when a V-Ray Dome light is present in the scene.
- With With V-Ray 6, update1update 1, instanced lights instanced by VRayInstancer , / Forest Pack , / Rail Clone, etc. must be are part of the Light Select render element RE of the respective source light. Multiple lights used with one instancer node must have separate Light Select entries in VRayLightMix.
Materials
Fresnel reflections always include glossy Fresnel algorithm. Therefore, the Glossy Fresnel option is hidden from UI for VRayMtl and VRayToon materials.
- The V-Ray Material Library Browser is replaced by the Chaos Cosmos Browser. The legacy browser is still usable but the plan is to retire it completely. We recommend using the materials from the Chaos Cosmos Browser for any new projects for the transition period.
