Example: Sky Model Types
The examples images below show the different sky model types. Here, default Default values for VRaySky have been used.
width10%
80
width80%
Image slider
Panel
borderStylenone
Image Modified
Preetham et al.
Panel
width10%
borderStylenone
width10%
80
width
Image Modified
CIE Clear
Panel
width10%
borderStylenone
width10%
80
width
Image Modified
CIE Overcast
Panel
width10%
borderStylenone
width10%
80
width
Image Modified
Hosek et al.
Panel
width10%
borderStylenone
width10%
80
width
Image Modified
PRG Clear Sky
width10%
Fancy Bullets
typecircle
  • With V-Ray 5, Update 1, some parameters have been hidden from the VRaySky's UI, namely the Sun size multiplier, Sun filter color, and Sun invisible. They are still available in the VRaySun's parameters.
