Input Texmap -- – The VRayOSLTex input texmap. (Only VRayOSLTex should be used as an input.)
Output Index – The index of the output that is selected(zero based). This parameter is linked to the Output Name parameter.
Output Name – The name of the output that is selected. Change the output by choosing a different one from the drop-down list. This parameter is linked to the Output Index parameter.
