The Dome light is a type of VRayLight that provides somewhat even lighting to a scene.
A Dome light is a type of VRayLight that shines inward at the scene as if from a spherical or hemispherical light source outside the scene extents. This light is frequently used for Image-Based lighting using panoramic HDR images used as environments.
UI Expand | ||||||||||||||||||||||||
Sample Use
In the images below, a dome light is positioned and is the only source of light in the render.
Parameters - General Rollout
Section | |||||||||||||||||||||
Parameters - Dome Light Rollout
Anchor | ||||
Example: How to embed an object in place into an HDRI
Align | ||
Example: Finite Dome
This example shows how enabling the Finite dome option adds depth to a scene's background and augments the lighting. It also adds a ground plane. With the Finite dome enabled, the object looks as if it is actually placed in the background scene.
Section | ||||||||||||||||||||||||||||||||
Example: Photon Emission
Anchor | ||||
Parameters - Options Rollout
Parameters - Sampling Rollout
Parameters - Viewport Rollout
Anchor | ||||
Fancy Bullets | ||
